A/C Bracket for B-Series into ek.
Old Jul 31, 2006 | 06:08 PM
SierraSonic's Avatar
Default A/C Bracket for B-Series into ek.
Hi, first post, I've been searching the forums for a while, and every time it gets a different answer, hopefully this one will get a good answer, Which brackets will work.
99 si?
96-76 vtec del sol?
crv?
integra?
Which ones work which dont?
Old Jul 31, 2006 | 06:10 PM
jp8900's Avatar
Default Re: A/C Bracket for B-Series into ek. (SierraSonic)
i have the del sol vtec one in my car when i had ac...
Old Jul 31, 2006 | 07:34 PM
polymath's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SierraSonic &raquo;</TD></TR><TR><TD CLASS="quote">Hi, first post, I've been searching the forums for a while, and every time it gets a different answer, hopefully this one will get a good answer, Which brackets will work.
99 si?
96-76 vtec del sol?
crv?
integra?
Which ones work which dont?</TD></TR></TABLE>
They both do. Here's the simple answer...get the Civic Si/Delsol vtec (its the same thing) or the CRV (which I hear is also identical).
The Integra bracket does bolt on to the motor and into the car, but the <u>Civic compressor does not fully bolt onto the Integra bracket</u>.
Using a Civic compressor = Use a Civic Si / Del Sol vtec / CRV bracket.
Old Aug 1, 2006 | 11:49 AM
Civichatch2k's Avatar
Del Sol
Old Aug 2, 2006 | 04:27 PM
polymath's Avatar
Default Re: A/C Bracket for B-Series into ek. (Civichatch2k)
Delsol bracket = Civic Si bracket
Old Aug 2, 2006 | 05:41 PM
slowcivic2k's Avatar
Default Re: A/C Bracket for B-Series into ek. (Coyote1800cc)
WRONG, civic si /= del sol, the d series motors all use the denso compressor, the only b-series vtec motor to use the denso compressor is the del slow, its part number is 38930-P54-000, its a guaranteed fit. the other b series motors use the sanden compressor.
LsVtakYO
Jan 15, 2014 05:21 PM
ATrin
12
Jul 22, 2006 08:47 AM
IT'S ME DAVID
17
Jul 18, 2006 07:55 PM
jimmhatch
May 13, 2005 05:43 AM
jdm jedi
Sep 14, 2003 03:21 PM
