WHAT AXLES TO USE FOR JDM ITR 5LUG CONVERSION ON MY INTEGRA..
i was wondering what axles would work?
i know i need 36mm (jdm itr) axles..but im having a hard time trying to find them..i heard that CRV axles are 36mm..would i be able to use those?? i dont have abs on my car so id have to get non-abs axles right? can i use the abs axles for my non-abs ride? other than the axles..it should just be straight bolt on right?
thanks in advance guys..
Raxles is what I have. Randy is a good guy. They are a little on the expensive side but I feel they are worth it. Just remember to ask for something that will take a 36mm axle nut.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Comp97GSR »</TD></TR><TR><TD CLASS="quote">Raxles is what I have. Randy is a good guy. They are a little on the expensive side but I feel they are worth it. Just remember to ask for something that will take a 36mm axle nut.</TD></TR></TABLE>
how much are those axles? and where do u get it from? what do u mean..ask for something thatll take the nut out? wouldnt it just be the 36mm socket?
still wondering if abs axles would work fine on non-abs car?? NEED ASSISTANCE!!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EGDC2CIVIC »</TD></TR><TR><TD CLASS="quote">http://www.raxles.com/</TD></TR></TABLE>
A guy I know is rocking them too. They are still solid after about 3500! (CV boot looks brand new still.
They got my vouch!
They got my vouch!
you can buy custom axles
OR
if you/or someone you know knows how to rebuild axles..you can swap out the outer half shaft with one from a prelude. you would have to double check on what year but they do come in 36mm
OR
From: 99 probs but a stolen car aint 1, ca, cerritos/fullerton
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SINFULintegXsi »</TD></TR><TR><TD CLASS="quote">you can buy custom axles
OR
if you/or someone you know knows how to rebuild axles..you can swap out the outer half shaft with one from a prelude. you would have to double check on what year but they do come in 36mm</TD></TR></TABLE>
Bingo- that how a local shop out does it.
OR
cool..so basically a non-abs car can use any axle..but a car with abs can NOT use non-abs axles..thanks honda tech
correct as long as the ring is removed you can use it. usually they have the same part numbers, but have a different ending letter at the end to specify ABS, same as a non-abs axle, it just has a ring.
my friend has a set of custom made stage 2 or 3 axles made for the larger jdm 5-lug if anyone is interested he might still have them and i can give him a ring and see if he wants to sell them.
1337 Si
Sep 9, 2011 04:28 PM
frankenstein ek9
Apr 5, 2008 10:52 AM
