Plastic door liner necessary?
Old Jul 31, 2006 | 05:18 PM
baun's Avatar
Default Plastic door liner necessary?
I want to put some Dynamat on my door frames. I won't have enough to cover the entire door and I'm worried I'll have any problems with keeping water out if I take out the entire plastic liner.
More easily put: if I take out the plastic door liners, will this have any negative effect on my doors (e.g., water getting into them when it rains)?
Old Jul 31, 2006 | 05:20 PM
hondadude's Avatar
Default Re: Plastic door liner necessary? (baun)
yes it is there as a moisture barrier. And it helps to keep out the cold air drafts as you are cruising down the road. In a few years you could have loads of mold growing on the inside of the door panel.
Old Jul 31, 2006 | 05:41 PM
baun's Avatar
Default Re: Plastic door liner necessary? (hondadude)
Thanks for the info! If you have any experience with working with Dynamat, do you think that sticking it to the inside of the door panel instead of the door itself (thus leaving the door liner intact) would work to decrease road noise from the outside?
P_Dink
Oct 4, 2009 06:30 PM
suhteevin
Jan 6, 2009 09:04 PM
KidMo
Jan 15, 2003 12:06 PM
98itR484
May 22, 2002 09:20 PM
