b18a1 mechanical vss problem and the car has a limp (ha ha)
Old Jul 31, 2006 | 03:57 PM
crxb18ls's Avatar
Default b18a1 mechanical vss problem and the car has a limp (ha ha)
For those with b18a1 crx's -- the cable is good leading from the vss to the gauge gluster. the car is also running limp mode. not sure what else there to it when i know have spark and fuel pressure. timing is good as well . the wires to the dist. correct . the coil isnt burnt out because its a whole new dist. (obd0) I've read left and right about the vss signal/amplifier is b16 on the ecu plug for pr4. So the question with all wiring and connections correct -- what else is there to look at ? Any answers from the tech gurus and anyone who would like to contribute are welcome.
Old Jul 31, 2006 | 03:59 PM
zccr-xsi's Avatar
what cels is coming up?? what year b18 do u have?
Old Jul 31, 2006 | 05:21 PM
crxb18ls's Avatar
Default Re: (vteckillenzc)
Code 17 showing and b18a1 set up as a 90 to 93 integra.
Old Jul 31, 2006 | 05:45 PM
zccr-xsi's Avatar
https://honda-tech.com/zerothread?id=468260
have u started the motor yet?
Old Jul 31, 2006 | 05:52 PM
crxb18ls's Avatar
( YEs ) after numerous checks on the spark plugs , fuel pressure, ecu plugs, bat connections, fuses under dash , fuses under hood. limp mode sucks!! haha when i first purchase the car for a 1000 with the swap done to it already. I took his probs for cheap and well i fixed two other codes --- 3or5 and 6 well those are gone and then it was the 17 well replaced the broken cable . Finally, where we are at now with still the 17 and the limp.
Old Jul 31, 2006 | 05:55 PM
crxb18ls's Avatar
Default Re: (crxb18ls)
is your crx the single zc or dual? i ripped up the track with a eg hb with a single zc. i was having times in the low 15s rip that beast but i still have the heart to bring a lil crx back to life if i can find one for a good price
Old Jul 31, 2006 | 05:58 PM
zccr-xsi's Avatar
DOHC zc
how does it run with the cel?hows it sound at idle?
Old Jul 31, 2006 | 06:26 PM
crxb18ls's Avatar
the vss cel i could care less but the limp mode keeps under 4grand and wont go any higher
Old Jul 31, 2006 | 06:51 PM
zccr-xsi's Avatar
hum?i dont think the vss coed would make it run that way.u usre your cam gears are lined up right?cause that will do it everytime.
Old Jul 31, 2006 | 07:00 PM
SVOboy's Avatar
I've had vss issues and it doesn't do that. It'll keep you out of vtec but that's not the issue here.
Old Jul 31, 2006 | 07:01 PM
zccr-xsi's Avatar
Default Re: (SVOboy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SVOboy &raquo;</TD></TR><TR><TD CLASS="quote">I've had vss issues and it doesn't do that. It'll keep you out of vtec but that's not the issue here. </TD></TR></TABLE>
i say its the timing not being right.more then likely the cam gears.
Old Jul 31, 2006 | 07:09 PM
crxb18ls's Avatar
limp mode is something electrical --- im just thinking here so how is timing on the belt // cam gears going to make my car run in that mode?
Old Jul 31, 2006 | 07:14 PM
zccr-xsi's Avatar
ok one if u got rid of your vss code your car wounldt be in limp mode.if your cam gears off a tooth it run run like ***.which is what it is running like now from what u have described.
Old Jul 31, 2006 | 07:16 PM
zccr-xsi's Avatar
go on over to pgmfi.org and read up on what limp mode is and does to your motor and ecu.
Old Aug 2, 2006 | 06:15 PM
crxb18ls's Avatar
I did go there and read up on limp mode -- its a serious problem. Though it sends in the ecu to safety , it still allows you only to get it somewhere and then park till fixed. (sucks) Therefore, I'm handing it over to the car gods.
Old Aug 2, 2006 | 06:57 PM
zccr-xsi's Avatar
cool hope you get her running.
Old Aug 2, 2006 | 08:48 PM
salman's Avatar
Vss only stop the Ecu to engage VTech and limiter comes down to 7500, As from my experience,
There is some thing esle wrong with ur car, replace the ECU, to ensure that its not ecu problem
Old Aug 2, 2006 | 08:53 PM
crxnj's Avatar
Default Re: (salman)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crxb18ls &raquo;</TD></TR><TR><TD CLASS="quote"> ( YEs ) after numerous checks on the spark plugs , fuel pressure, ecu plugs, bat connections, fuses under dash , fuses under hood. limp mode sucks!! haha when i first purchase the car for a 1000 with the swap done to it already. I took his probs for cheap and well i fixed two other codes --- 3or5 and 6 well those are gone and then it was the 17 well replaced the broken cable . Finally, where we are at now with still the 17 and the limp. </TD></TR></TABLE>
Did you reset the ecu yet?
Old Aug 3, 2006 | 12:45 PM
crxb18ls's Avatar
Salman and Mr.speaker did that and the car still failed...back to salman though -- ihave no vtec on my b18 i sure it wouldnt take much to set it up but i then i have to get the controller , knock sensor, etc-- blah blah you know the deal... i want my car to run lol and i want to start the body work soon
Old Aug 12, 2006 | 05:29 AM
crxb18ls's Avatar
Car is going to be worked on by RC Autoworks... car will and hopefully run again.
averyvm
10
Jun 16, 2010 02:41 PM
jdeeezy
Jul 19, 2008 11:32 AM
Karna
Feb 13, 2008 07:37 PM
Hella_Fresh
19
Mar 31, 2007 12:35 AM
