TPS SENSOR QUESTION
Old Jul 31, 2006 | 03:38 PM
GsrTurboCRX88's Avatar
Default TPS SENSOR QUESTION
would a bad tps cause my crx with a ls vtec motor cut out alot at low rpms and when I am first starting it it dies right away, especially when I press the gas after I start it it will die. It doesnt die after a minute or two after warming up. It wasnt doing this the other day but then i broke the sensor on accedent and has been doing this ever since
Old Jul 31, 2006 | 03:40 PM
Default Re: TPS SENSOR QUESTION (GsrTurboCRX88)
I am wondering because the only code I am throwing is a speed sensor and o2 sensor. If the tps was bad wouldn't it throw a code?
Old Jul 31, 2006 | 05:31 PM
crxb18ls's Avatar
i would have to say to no to that because if the voltage is correct and the wiring is good. the position of tps may not be correct to idle right.
Old Jul 31, 2006 | 05:56 PM
digitally_remastered's Avatar
lol..... im not even running a tps sensor a the time on my mpfi swap. it runs pretty well and idels fine(900-1100 rpm).
Old Jul 31, 2006 | 06:18 PM
crxb18ls's Avatar
if thats the case i would leave it alone -- another thing ( i dont use turbo ) im an all motor fan.. nothing against turbos c'mon who doesnt like that kind of power. how did you bypass the tps? im curious
funz0rzies
Honda Civic (2001 - 2005)
Mar 25, 2015 07:00 PM
OBDII Integra
Apr 16, 2008 09:54 AM
