Pulled spark plug wire, now no start
Old Jul 31, 2006 | 02:55 PM
CLE's Avatar
CLE
Default Pulled spark plug wire, now no start
Car was running fine, no CELS, being the smart guy I am I decided to pull the plug wires. Pulled wire 4, nice blue sparks engine still ran decent, replaced it, pulled plug 3, engine died. I put the wire back in and cranked her up and now she won't start. Have not yet checked for fuel/spark, checked ecu and main fuse, also the alternator fuse.
Has anyone else ran into this problem? Is there another possible fuse that it could be if i blew one? Meanwhile I'll pray to the dizzy god that I did not jack up the ignition coil.
Old Jul 31, 2006 | 04:07 PM
Crx Jimmy's Avatar
Default Re: Pulled spark plug wire, now no start (CLE)
inside the wire the end could have come off and stuck to the plug or the wire itself inside could have broken
Old Jul 31, 2006 | 04:58 PM
CLE's Avatar
CLE
Default Re: Pulled spark plug wire, now no start (Crx Jimmy)
Wires in good condition plugs too.
Old Jul 31, 2006 | 05:17 PM
y-49's Avatar
change ur wires they are bad about comin apart
Old Jul 31, 2006 | 06:24 PM
CLE's Avatar
CLE
Default Re: (yellow rex)
any other ideas
Old Jul 31, 2006 | 08:52 PM
CLE's Avatar
CLE
Default Re: (CLE)
Decided to go out in the middle of the night and crank it, got it to start it bogged some, im guessing i flooded it, cause it smelt like gas bad.
Old Jul 31, 2006 | 09:07 PM
nelsmar's Avatar
pretty hard to flood an automatic. as vacum is how the ecu determines how much fuel to put in. (i know its posible yes i have done it... with large injectors and holding the ignition to long).
but if you think you have. pull the plugs out for 5 mins... then put them back in and try again.
do you have a multi meter? check the wires. see if they are alright. if you pull d 1 wire... and had 3 in and the motor shut off... im not sure about that
Old Jul 31, 2006 | 09:37 PM
slowcrxsib16's Avatar
i dont get it, why were you pulling the plug wires off while the car was running, that doent make sense to me, unless im missing something
Old Jul 31, 2006 | 10:47 PM
CLE's Avatar
CLE
Default Re: (nelsmar)
The car starts now and its not an automatic! And I pulled wires cause im cool like to create problems for myself.
Old Aug 1, 2006 | 02:43 AM
94VXLSHatchie's Avatar
Default Re: (CLE)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CLE &raquo;</TD></TR><TR><TD CLASS="quote">The car starts now and its not an automatic! And I pulled wires cause im cool like to create problems for myself.</TD></TR></TABLE>
then might as well solve them yourself
Old Aug 1, 2006 | 10:36 AM
nelsmar's Avatar
pull the wires while its on to check if you are sparking all four cylenders. thats the reason ive done it in the past
Old Aug 1, 2006 | 08:23 PM
CLE's Avatar
CLE
And yes thats the reason, I was just being a smart ***.
PsXtreme
Jun 26, 2016 01:43 PM
imroadk1ll
Mar 23, 2010 04:21 PM
vsmftw98
Aug 4, 2009 02:14 PM
95DC2GS-R
Dec 21, 2008 08:54 PM
PerfectTechs
Mar 23, 2008 10:15 AM
