94 Accord baugs out when u first accelerate WHY???
Old Jul 31, 2006 | 02:42 PM
JonCoop's Avatar
Default 94 Accord baugs out when u first accelerate WHY???
in 1st adn the begining of second when u floor it all it does is baugs out for 2 or 3 seconds then takes off.. what could be causeing this???
fuel filter????
Old Jul 31, 2006 | 03:58 PM
hondaccord's Avatar
Default Re: 94 Accord baugs out when u first accelerate WHY??? (JonCoop)
yes the air/fuel fillter, fuel pump, or injectors can all cause this.
Old Aug 4, 2006 | 06:14 PM
HondaCrx687494's Avatar
hey,
my friend has a 92 accord LX and his did the same thing, I aggree with the other response but I think it is the o2 censor. it isn't reading properly therefore is starves the engine from gas for a moment or two then it snaps out of it. I hope this helped
Paul
Old Aug 4, 2006 | 06:52 PM
hondaccord's Avatar
Default Re: 94 Accord baugs out when u first accelerate WHY??? (HondaCrx687494)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HondaCrx687494 &raquo;</TD></TR><TR><TD CLASS="quote">hey,
Paul </TD></TR></TABLE>
the thing is that if it was the o2 sen. the cel would light up, and through a o2 code. You are right that the ecm controls the amount of fuel threw the o2 though. first you should check the fuel pressure. that will determine if the fule filter or pump are bad. also check your main relay.
Old Aug 4, 2006 | 07:03 PM
philadd's Avatar
Default Re: 94 Accord baugs out when u first accelerate WHY??? (hondaccord)
A "lazy" O2 sensor can cause this exact problem, without triggering a CEL.
If I had to lean towards one possibility, I would say it was the O2 sensor.
Old Aug 4, 2006 | 11:01 PM
H22A 94Inspire's Avatar
If the O2 sensor is bad then the motor would run rich
Old Aug 5, 2006 | 04:15 AM
milesnic's Avatar
what ever you do, don't buy a bosch o2 sen. only get a honda.......bosch doesn't respond as quick and will burn out in less than a yr.
Old Aug 5, 2006 | 05:17 AM
hondaccord's Avatar
Default Re: (milesnic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by milesnic &raquo;</TD></TR><TR><TD CLASS="quote">what ever you do, don't buy a bosch o2 sen. only get a honda.......bosch doesn't respond as quick and will burn out in less than a yr.
yep I made that mistake, you think you save a little, but end up spendding more. Also I didn't know it wouldn't throw a code. Is that only on intermitent probs?
Old Aug 5, 2006 | 09:28 AM
philadd's Avatar
Default Re: (hondaccord)
No... In my experience, O2 sensors go bad gradually. At first, the only symptom would be a very slight hesitation after the car is first started, but when warmed up everything is fine. Then, as the sensor gets worse, the stumble/hesitation gets worse. Eventually, the CEL will come on.
Of course, the heater circuit can go bad almost instantly, but that would trigger a CEL before you would notice any problems.
JonCoop,
Here are the things that I would recommend checking:
1. O2 sensor
2. Clogged fuel filter
3. Ignition timing
4. spark plugs
Old Aug 8, 2006 | 05:47 AM
hondaccord's Avatar
Default Re: (philadd)
cool learn something new every day. thanks philadd, but with the o2 heater, is there any cheep and easie way to fix this? I know get an oem sens, damn there just so expensive.
Old Aug 8, 2006 | 10:43 AM
philadd's Avatar
You could add a resistor inline on the heater circuit, which would fool the ECU into thinking the heater circuit is performing normally. However, I think it would be best to just replace the sensor. O2 sensors have to be at a high temp to work correctly... I think it's something like 600* F. The heater circuit is works to get the sensor up to that temp.
Old Aug 10, 2006 | 04:03 PM
JonCoop's Avatar
thanks guy for every thing...
i just replaced the o2 sensor with no noticable difference.. im gonna change my fuel filter tomorrow..
i changed my spark plugs and wires a month ago also with no difference..
i used $2.00 autolites.. is there a noticable difference between them and some ngk's???
thanks
1994 honda accord ex
Old Aug 10, 2006 | 04:09 PM
LSV84's Avatar
Default Re: (JonCoop)
if thats doesn't help i recommend you check the sock on the fuel pump for debris buildup. i have been suffering from shitty gas tank(rust) depositing crap all over the sock and causing jerking. i changed the pump once and now its back again, i should of did it right the first time and changed the gas tank too...i'm hoping i dont have to get another pump.
Old Aug 10, 2006 | 04:22 PM
technine's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JonCoop &raquo;</TD></TR><TR><TD CLASS="quote">thanks guy for every thing...
thanks
1994 honda accord ex</TD></TR></TABLE>
I don't think the spark plugs matter too much, but did you change cap and rotor too?
Old Aug 11, 2006 | 12:42 AM
philadd's Avatar
Default Re: (LSV84)
If you are having a problem with the gas tank, that could very well be the problem in itself. I personally have not seen an issue with rust on the inside of the gas tank, but it would definitely cause some problems. If you have a lot of loose sludge on the bottom of the tank, that could cause problems as well. If it's sludge, you can have the tank cleaned out. If it's rust... well, you'll need to get a new tank.
As for the plugs, I don't believe there could be enough difference between the two brands to cause any issues, assuming that they are correctly gapped.
civicfan14
Jan 12, 2011 06:37 PM
89D15CRXDX
Jun 13, 2008 08:05 AM
professorman
Jul 19, 2007 09:37 AM
accord-h22
Mar 10, 2007 08:33 AM
jwogen1
Jan 19, 2004 05:28 AM
