H23 header on F22?
Old Jul 31, 2006 | 02:32 PM
94preludeguy's Avatar
Default H23 header on F22?
Okay YES I searched but I just want to make sure this is correct before I purchase.
Guy locally said he'd sell me a Chickira header for 20 bucks and it's for an h23. Now I searched and people said it will bolt right up to a F22. I have a F22a1. Already got exhuast and intake, so this will finish the bolt-on stage.
Thanks in advance for any help.
Old Jul 31, 2006 | 02:50 PM
SKDRCR's Avatar
Default Re: H23 header on F22? (94preludeguy)
actually, I believe they are different.
Old Jul 31, 2006 | 03:12 PM
v4lu3s's Avatar
RTFM
yes it fits just fine.
h23a1 and f22a# series engines share the same exhaust ports.
you can alkso compare the exhaust manifold gaskets at http://www.slhondaparts.com and see they are both 18115-PT0-004
Old Jul 31, 2006 | 06:46 PM
korney's Avatar
Default Re: (v4lu3s)
Yes it will fit!!!!
h23= 0-0-0-0
f22a1= 0-0-0-0
f22b1=0--0-0--0
yes yes it will fit my buddy has a f22a1 and he has a h23a1 megan header....
Old Jul 31, 2006 | 06:49 PM
SKDRCR's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by v4lu3s &raquo;</TD></TR><TR><TD CLASS="quote">yes it fits just fine.
you can alkso compare the exhaust manifold gaskets at http://www.slhondaparts.com and see they are both 18115-PT0-004 </TD></TR></TABLE>
very nice, i stand corrected. so that means technically one could
swap the talon/eclipse junkyard turbo setup on an h23 instead
of the regular f22 junkyard setup.
Old Jul 31, 2006 | 07:38 PM
Finest's Avatar
Default Re: (SKDRCR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SKDRCR &raquo;</TD></TR><TR><TD CLASS="quote">
of the regular f22 junkyard setup.</TD></TR></TABLE>
But you're going to need something bigger than the t25/14b. 20g or bust!
Old Jul 31, 2006 | 08:07 PM
InvaderTrax's Avatar
You'll also need to extend the wires for the O2 sensor. H23 is on the bottom by the flexpipe and the F22 is on top
Old Aug 1, 2006 | 01:40 AM
Thanks for the help.
So I'll have to rewire the 02 sensor? Also a Chikira header should bolt onto the stock downpipe right? Or would I have to get it welded?
Old Aug 1, 2006 | 05:51 AM
flyrod's Avatar
Default Re: (94preludeguy)
If your F22 does not have the siamesed exhaust ports the H23 header should bolt to the head. I think you will need to do some modifications further down though... Let us know how it goes!
Old Aug 1, 2006 | 06:47 PM
v4lu3s's Avatar
RTFM
the only modification ic an think of is there being a very slim chance that the flange for the A pipe to catalytic converter is diffneret, the length is absolutley perfecty the same between 90-93 accords and 92-96 preludes when it comes to the length of the A pipe.
Old Aug 2, 2006 | 09:43 PM
Well I got it sanded and painted. Going on tomorrow, I'll post results and photos.
Old Aug 2, 2006 | 10:22 PM
Heres what it looked like when I got it.
After some sanding.. it was a bitch getting that rust off.
Finished product
Also sanded off the logo part to make it silver again.
I'll post results tomorrow.
If I run into a problem with the O2 sensor.. think I could just take it to a shop and have them drill a hole and weld it into a pipe or something?
Old Aug 2, 2006 | 10:29 PM
What are you using for a down pipe (didn't see one pictured so I thought I'd ask)?
Old Aug 2, 2006 | 10:47 PM
korney's Avatar
Default Re: (InvaderTrax)
for the O2 sensor, just use some 12 gage wire and extend it to the lower O2 plug. (thats what we did) or yes you can just ask a shop to drill a hole. make sure if you do drill, have a plug or something to plug out the O2 hole behind the flex pipe.
Hopefully you have the h23 down pipe, the f22 will not work...
Old Aug 3, 2006 | 11:43 AM
Default Re: (korney)
Yeah figured that out the hard way.. Everything looked fine except for the downpipe.
A stock H23 downpipe would work though? Cause I could probably get one for free.
Old Aug 3, 2006 | 06:08 PM
korney's Avatar
does the stock h23 have a 4-2-1 header? if not, it wont work...well for the f22a1, its a 4-1...
Old Aug 3, 2006 | 10:02 PM
It's all good.. I'm getting the downpipe tomorrow but he says the flexpipe is messed up... All I really need is the flange though.
Old Aug 3, 2006 | 10:20 PM
korney's Avatar
alright...post pics when you get it installed...
Old Aug 9, 2006 | 11:19 PM
I got a downpipe from a junkyard, just waiting to install it. Probably just going to take it to a buddy's shop and install everything then cut the old downpipe off then weld the new one.
I'm pretty stoked. I'm thinking I should get atleast 20 more horsepower because of the new downpipe.
All-Motor-Junkie
Mar 12, 2008 07:45 PM
ericstambaugh07
Jan 27, 2007 05:14 PM
projectwidow
May 9, 2006 06:40 AM
da9wonder
Feb 3, 2006 09:09 AM
AlexLude
Jul 27, 2005 09:25 PM
