removeing dash??
well there is one in the center of the dash up near the windshield, theres a little plastic peice you have to pull out. on each end of the dash you have to pull the vent off that meets the doorpanel, and theres one there. adn down below that there is one on each side, you'll probably ahve to pull the glovebox. and down under the radio is one near the floor. I think that is all. good luck. you will also have to take your gauge cluster out.
Pop off the H emblem on the steering wheel.
Get a 19mm socket and remove the steering wheel nut.
Pull the steering wheel off.
Might want to also remove the turn signal/wiper portion as well, you may snap one of the arms off when trying to pull the dash off.
I took the wheel, wiper arm portion and the steering column plastic off when I removed the dash on mine since I am redoing the entire interior.
Follow this link, and download the service manual.
https://honda-tech.com/zerothread?id=170014
You'l have to look at the pages in a mirror though it's RHD
