tail light problems
Old Jul 31, 2006 | 01:24 PM
Projekt_2nr's Avatar
Default tail light problems
have a 95 CIVIC LX Sedan, ok so far i've been pulled over twice for my brake lights. the problem that im having is that when i put enough pressure on the brakes to turn on the brake lights, all brake lights will work except the passenger side rear brake lights. and the thing i dont get is ive checked all fuses and when i turn on my running and driving lights the bulbs for the passenger side will illuminate but when i apply pressure to the brake pedal they wont! can anyone and everyone please help me with this because i need TO FIX THIS PROBLEM BEFORE I HAVE TO DRIVE BACK OUT TO IDAHO FROM WISCONSIN! thanks id appreciate all the help.
Old Jul 31, 2006 | 01:28 PM
Padawan's Avatar
Darth ModerVader
Default Re: tail light problems (Projekt_2nr)
Is it safe to assume you've already checked the bulb?
Old Jul 31, 2006 | 02:02 PM
slo93si's Avatar
Default Re: tail light problems (Padawan)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Padawan &raquo;</TD></TR><TR><TD CLASS="quote">Is it safe to assume you've already checked the bulb? </TD></TR></TABLE>
. Brake lights have two fillaments. One for your tail-lights and one that illuminates when you depress the brake pedal. Maybe you should check that out.
turbosir89
19
May 4, 2018 12:17 PM
Kevs02Accord
Oct 30, 2009 12:20 PM
IOSUA
Nov 20, 2007 11:08 AM
Projekt_2nr
Jul 31, 2006 09:06 AM
