JDM D15B and D16Z6 head the same? or different?
i have a VX and i know the block is same as jdm d15b. I want to put a d15b or d16z6 head on, just want to make sure it's same or are they different?
The heads are pretty much the same, its the block and assemblies (rods, pistons, etc) that are different.
now this is where it's confusing. Everyone says the JDM D15B uses a VX block, but on the swap FAQ, says do not put a d15b/d16z6 head onto a VX block. So what is it?
not to take away from honda-tech.. but this is a great site for d series building:
http://www.d-series.org/forums/index.php
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bluesaint »</TD></TR><TR><TD CLASS="quote">now this is where it's confusing. Everyone says the JDM D15B uses a VX block, but on the swap FAQ, says do not put a d15b/d16z6 head onto a VX block. So what is it? </TD></TR></TABLE>
all d15's with vtec (whether it's vtec or vtec-e) use the same block.
all d15 non vtec's use the same block.
the d15 vtec's use a longer 137mm rod. And the d15non vtec uses a 134mm rod.
d15z1 (vx) is a freakshow. it has ultra deepdish pistons which when paired up to a d16z6 cylinder head or a d15b cylinder head, you'll have ultra low compression.
if all d15's with vtec use same block, why can't you put a jdm d15b head on a d15z1?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bense »</TD></TR><TR><TD CLASS="quote">
d15z1 (vx) is a freakshow. it has ultra deepdish pistons which when paired up to a d16z6 cylinder head or a d15b cylinder head, you'll have ultra low compression.</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bluesaint »</TD></TR><TR><TD CLASS="quote">if all d15's with vtec use same block, why can't you put a jdm d15b head on a d15z1?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bense »</TD></TR><TR><TD CLASS="quote">d15z1 (vx) is a freakshow. it has ultra deepdish pistons which when paired up to a d16z6 cylinder head or a d15b cylinder head, you'll have ultra low compression.</TD></TR></TABLE>
too low compression = running like ****
WhiteyW/AHonda
Sep 11, 2011 04:49 PM
90-honda-crx-hf
Jul 14, 2011 01:59 PM
