Clutch type LSD which MTF??
Old Jul 31, 2006 | 11:35 AM
garyc17's Avatar
Default Clutch type LSD which MTF??
Hi, I have a Spoon LSD in my B18c5 tranny. What is the recommended MTF for a clutch type LSD like Spoon? What happens if the wrong MTF is used? I am currently on some castrol MTF and the car feels rough. Will the wrong MTF cause the car to hesitate on the freeway when I go over uneven road surfaces?
Old Jul 31, 2006 | 11:46 AM
Dave_B's Avatar
PM user Walker111. he's got a Cusco clutch type diff. I *think* he used pensoil but i'm not sure exactly.
Old Jul 31, 2006 | 01:14 PM
Sehc Tib Alli Zerif!!!!!'s Avatar
cool guy name
Default Re: (Dave_B)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dave_B &raquo;</TD></TR><TR><TD CLASS="quote">PM user Walker111. he's got a Cusco clutch type diff. I *think* he used pensoil but i'm not sure exactly.</TD></TR></TABLE>
Thats correct, I use Penzoil Synthetic gear oil 75-90 GL5
Old Jul 31, 2006 | 01:33 PM
RagingAngel's Avatar
Redline MTL plus Ford Friction modifier works good also.
I used this with good results when I had my kaaz. I found the kaaz oil to be very notchy on cold mornings while the MTL/Fric. mod remained smooth but also kept the LSD quiet.
Old Jul 31, 2006 | 01:54 PM
Mugen Mike's Avatar
Default Re: Clutch type LSD which MTF?? (garyc17)
A gear oil with a friction modifier such as Redline MT-90 (which is what I use), or even regular old Honda MTF with a friction modifier additive will work fine.
Old Jul 31, 2006 | 04:36 PM
le diable's Avatar
how about royal purple tranny fluid . i used their engine oil and it works great ,also running their rad coolant additive.
Old Jul 31, 2006 | 04:58 PM
Propulsion's Avatar
Default Re: Clutch type LSD which MTF?? (le diable)
where do you guys buy the friction modifier stuff?
Old Jul 31, 2006 | 09:30 PM
garyc17's Avatar
Default Re: (walker111)
I have been running without any friction modifier for 10000miles already. Is my LSD in trouble? When I make right turns there's this clicking noise from the right wheel, but there's non for left turns. My CV boots are okay.
Old Aug 1, 2006 | 06:12 AM
Mugen Mike's Avatar
Default Re: (garyc17)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by garyc17 &raquo;</TD></TR><TR><TD CLASS="quote">I have been running without any friction modifier for 10000miles already. Is my LSD in trouble?</TD></TR></TABLE>
It could cause premature wear of the disks.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by garyc17 &raquo;</TD></TR><TR><TD CLASS="quote">When I make right turns there's this clicking noise from the right wheel, but there's non for left turns. My CV boots are okay.</TD></TR></TABLE>
That doesn't necessarily mean that the joints are okay.
Old Aug 1, 2006 | 07:03 AM
cool guy name
Default Re: (Mugen Mike)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mugen Mike &raquo;</TD></TR><TR><TD CLASS="quote">A gear oil with a friction modifier such as Redline MT-90 (which is what I use), or even regular old Honda MTF with a friction modifier additive will work fine.</TD></TR></TABLE>
Joo dont run what king recommends?
Old Aug 1, 2006 | 07:05 AM
Mugen Mike's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by walker111 &raquo;</TD></TR><TR><TD CLASS="quote">
Joo dont run what king recommends?</TD></TR></TABLE>
Redline MT-90 is what they recommended.
Old Aug 1, 2006 | 07:20 AM
cool guy name
hmmm?? Last time I was on there site they recommended the penzoil..
Old Aug 1, 2006 | 07:23 AM
cool guy name
GL-4 synthetic oil (75W-90) or equivalent should be used.
Ok maybe not....
Old Aug 4, 2006 | 10:40 AM
garyc17's Avatar
Basically how do I know I have used the wrong MTF? LSD chattering noises or what are the symptoms? By the way, the clicking I mentioned when I make right turns, if my CV joint is the fault and I just continue to drive. What might happen?
Old Aug 4, 2006 | 12:03 PM
cool guy name
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by garyc17 &raquo;</TD></TR><TR><TD CLASS="quote">Basically how do I know I have used the wrong MTF? LSD chattering noises or what are the symptoms? By the way, the clicking I mentioned when I make right turns, if my CV joint is the fault and I just continue to drive. What might happen?</TD></TR></TABLE>
Your axle will eventually break. More than likely its just the diff...
Old Aug 4, 2006 | 05:16 PM
Black R's Avatar
25 Year Member
or
Old Aug 4, 2006 | 09:51 PM
realis9's Avatar
Default Re: Clutch type LSD which MTF?? (Black R)
are you guys talking about using friction modifier on factory LSD or aftermarket LSD?
Old Aug 4, 2006 | 11:58 PM
Black R's Avatar
25 Year Member
Default Re: Clutch type LSD which MTF?? (realis9)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by realis9 &raquo;</TD></TR><TR><TD CLASS="quote">are you guys talking about using friction modifier on factory LSD or aftermarket LSD?</TD></TR></TABLE>
I'm talking about aftermarket CLUTCH TYPE LSD. Helical shouldn't need a friction modifier, nor should it need this weight oil.....
Old Aug 5, 2006 | 01:28 AM
garyc17's Avatar
But if it was really only my diff chattering, why does it chatter only on right turns? Is it because the driveshaft is shorter on that side of the car?
Old Aug 5, 2006 | 08:39 PM
SuperSteve737's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by garyc17 &raquo;</TD></TR><TR><TD CLASS="quote">But if it was really only my diff chattering, why does it chatter only on right turns? Is it because the driveshaft is shorter on that side of the car?</TD></TR></TABLE>
Um, the driveshafts are the same length.
Old Aug 9, 2006 | 08:45 AM
garyc17's Avatar
Opsss. didn't know that the shafts are the same length.. Had an old Mitsubishi and they were of different lengths. So anyone know's why it chatters on right turns only?
Old Aug 10, 2006 | 03:56 PM
GUILOTINE's Avatar
Kill Gil
when I spoke to Kaaz they recommended either their gear oil or regular GLW4 Pennzoil Gear Oil. The gear oil isn't good for the Honda synchros though. Kaaz also strongly warned against using Synthetic Fluids, such as Redline with a Clutch type LSD. What happens is that the synthetic fluids leave a coating on the clutch plates that will eventually cause them to start slipping.
I have been using regular Honda MTF tranny fluid with a few drops of Redline LSD friction modifier, the more modifier you use the less it chatters
Old Aug 10, 2006 | 06:04 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by garyc17 &raquo;</TD></TR><TR><TD CLASS="quote">Opsss. didn't know that the shafts are the same length.. Had an old Mitsubishi and they were of different lengths. So anyone know's why it chatters on right turns only?</TD></TR></TABLE>
Yeah, the axles are the same length. Us Honda boys use a halfshaft, on the drivers side of the tranny, to make the CV axles the same length.
Old Aug 11, 2006 | 09:03 AM
garyc17's Avatar
Default Re: Clutch type LSD which MTF?? (Mugen Mike)
Why don't I just use Redline 75w90 which comes with friction modifier additives? I hear it may shorten the syncro life due to GL-5 rating and also it will be slightly more notchy. Is this true?
Old Aug 11, 2006 | 09:05 AM
garyc17's Avatar
Default Re: (GUILOTINE)
What about using Redline MTL? That would be good for the syncros, but bad for the LSD. Is there any way I can come to a resonable balance of protection?
