Whats the correct a/c operating PSI for 5th gen?
Old Jul 31, 2006 | 11:31 AM
stickercuttingcom's Avatar
Default Whats the correct a/c operating PSI for 5th gen?
Just curious what the pressure should be for a 96' accord a/c system?
My a/c works, but isn't that strong. The gauge that I have shows that it is charged (its from autozone), but I am thinking maybe the"universal" filled reading on the gauge may be too low.
Does anyone know the proper pressure for maximum cooling?
Old Jul 31, 2006 | 12:03 PM
Intense3.2's Avatar
Default Re: Whats the correct a/c operating PSI for 5th gen? (stickercuttingcom)
What do you mean by "isnt that strong" ..... ?
Old Jul 31, 2006 | 12:05 PM
Ross 2.0's Avatar
In a Junkyard near you.
PM me with your email adress and i can send the guide to you
Old Jul 31, 2006 | 07:44 PM
The guide really didn't help.
Isn't there a "normal operating" PSI?
What I mean by Not that strong is it isn't that cold...
Old Aug 1, 2006 | 06:49 AM
v4lu3s's Avatar
RTFM
there is a range of acceptable PSI's that depend on milage condition, type of refrigerant etc. also outside air temp, and temperature out the vents comes into play.
I would assume of you are askign this questions that you have a stadard dual gauge ac set to read both high and low side pressure?
Old Aug 1, 2006 | 08:36 AM
amckee's Avatar
Default Re: (stickercuttingcom)
Low side pressure can range from 30 psi at 65 degrees outside air temp, to 50 psi at 95 degrees. If you are within these specs, make sure that both cooling fans run when the ac is on and also make sure that the temp control **** is fully actuating the air mixture door on the blower. If you are mixing evaporator air with heater core air, it's not going to be very cool. Does that generation car have a cabin air filter?
gkitf16
12
Jun 4, 2022 07:50 PM
RA022626
10
Sep 7, 2016 08:23 AM
thinkskater007
30
Sep 3, 2013 08:27 PM
servion
Jun 23, 2004 07:56 AM
