exedy clutch problem
Old Jul 31, 2006 | 09:14 AM
ITR 01 1101's Avatar
Default exedy clutch problem
hey guys i have a problem with the R. its all stock besides an intake.
i put in a new exedy stage 1 clutch and had the flywheel resurfaced
and now the car wants to go as soon as the clutch pedal is starting
to be released. there is no more play down there any more is this
normal for an exedy stage 1 ? i also have a 2000 si (b16) with a cheep
stage 1 and is not like this .....please help
Old Jul 31, 2006 | 09:21 AM
RagingAngel's Avatar
I believe this is a common issue with a moderate amount of Exedy installs.
The clutch pedal's free play has to be adjusted. There will be threads on how to do this from other members who have had the same issue.
It involves loosening the nut and twisting the master cylinder's shaft.
For this very reason, I have never used a full Exedy clutch, but just recently installed one...and pray I don't have to do this shiet to get it to work....
Old Jul 31, 2006 | 09:23 AM
Dave_B's Avatar
Default Re: (RagingAngel)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RagingAngel &raquo;</TD></TR><TR><TD CLASS="quote">
Yep, that's pretty much it. You adjust the play in the pedal. Some like it closer to the floor, and others like it up top. It's personal preference really.
Old Jul 31, 2006 | 10:02 AM
mstewar's Avatar
Default Re: (Dave_B)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dave_B &raquo;</TD></TR><TR><TD CLASS="quote">
Yep, that's pretty much it. You adjust the play in the pedal. Some like it closer to the floor, and others like it up top. It's personal preference really.</TD></TR></TABLE>
if you drove a car that had the exedy clutch/pedal problem, you would call it more than personal preference..
Old Jul 31, 2006 | 10:07 AM
Dave_B's Avatar
Default Re: (mstewar)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mstewar &raquo;</TD></TR><TR><TD CLASS="quote">
if you drove a car that had the exedy clutch/pedal problem, you would call it more than personal preference.. </TD></TR></TABLE>
That's not what I was saying though, you can adjust to personal preference.
&lt;--- Never had a problem with his Exedy setup.
turbo-crx
Jun 19, 2008 02:00 PM
Benjithx
Nov 14, 2004 12:00 AM
nyzpapi4u
Oct 18, 2004 07:35 AM
shotty527
Nov 2, 2003 09:00 PM
Que_Lude
Oct 27, 2003 06:52 PM
