Anyone Experience release bearing return spring problems on 88-91 civic clutches?
Old Jul 31, 2006 | 07:11 AM
91civicshaw's Avatar
Default Anyone Experience release bearing return spring problems on 88-91 civic clutches?
I have swapped 2 motors in civics (keeping same trans on each) and have had problems with the throw out bearing return springs breaking causing the bearing to jam in the clutch so it won't release and clutch won't disengage - any fixes for this? The last swap I did - I didn't even touch the release arm / bearing / return spring. HELP!
Old Jul 31, 2006 | 09:15 AM
91civichatch's Avatar
Default Re: Anyone Experience release bearing return spring problems on 88-91 civic clutches? (91civicshaw)
Get a new spring and make sure it's installed right. Oh and make sure u grease the shaft nicely, but not too much that it would get all over the clutch. Also before installing it move the arm up and down and look at the bearing and make sure it slides smoothly and that nothing is causing it to jam
Old Jul 31, 2006 | 11:04 AM
Default Re: Anyone Experience release bearing return spring problems on 88-91 civic clutches? (91civichatch)
thanks for the info
BobbyRodriguez
Transmission & Drivetrain
Dec 19, 2011 07:46 AM
Kolijian
Oct 31, 2005 07:22 AM
drudy
Jun 12, 2005 04:24 PM
Full Race A6
34
Sep 11, 2004 09:22 PM
therealciviczc
Apr 9, 2002 03:19 PM
