Proper Install Procedure for OEM Pads?
Old Apr 23, 2002 | 11:52 AM
onyx00's Avatar
Default Proper Install Procedure for OEM Pads?
The Helms manual talks about using the shims that come with the new pads. Should these be used? I know on my Hawk HP+ pads people said not to use the shims; so I was wondering if the same went for the OEM pads. Also, any general tips on installing new OEM pads?
Thanks!
Old Apr 23, 2002 | 12:19 PM
JPP's Avatar
JPP
Default Re: Proper Install Procedure for OEM Pads? (onyx00)
Use the shim on the OEM pads. Put some anti-seize compound where mentioned on the manual.
Old Apr 23, 2002 | 12:37 PM
B2FiNiTY's Avatar
http://go.to/NGM -> car resources -> you know...
Thanks to monkey_truckR
Old Apr 23, 2002 | 03:09 PM
onyx00's Avatar
Default Re: Proper Install Procedure for OEM Pads? (B2FiNiTY)
Awesome thanks. Just FYI, the rear brake pad change page on the site doesn't work but I found his original post about it so no big deal.
Old Apr 23, 2002 | 03:10 PM
B2FiNiTY's Avatar
Thanks.
Old Apr 23, 2002 | 03:16 PM
onyx00's Avatar
Anyone know if there is a difference between anti-sieze lubricant and the anti-squeal stuff? If I don't use the Molycote M77 that comes with the stock pads, which of the two would I use?
Old Apr 23, 2002 | 03:17 PM
B2FiNiTY's Avatar
Use anti-squeel because anti-seize is for helping bolt removal on rusted or old bolts.
SPOOLINmatt
Mar 13, 2010 10:01 AM
onemanlan
Oct 31, 2004 02:38 PM
phatnadz
May 5, 2003 05:20 AM
rus
Oct 5, 2002 07:39 PM
onyx00
Apr 24, 2002 07:57 PM
