1990 civic hatch with b18b
Old Jul 30, 2006 | 10:37 PM
ls_efhatch's Avatar
Default 1990 civic hatch with b18b
what is a better tranny to use with a stock b18b would the ls or b16? all it has is intake header exhaust and a stage 4 act clutch planning on going turbo but that will be later. i need something for good accel.. just for now cause its not putting out alot of power i have both trannys but trying to decide what one to use.
Old Jul 30, 2006 | 10:54 PM
31flavorscivic's Avatar
Default Re: 1990 civic hatch with b18b (ls_efhatch)
b16
and that stage 4 clutch will in all likelihood break your pedal assembly
Old Jul 30, 2006 | 11:03 PM
njcrxsi's Avatar
Default Re: 1990 civic hatch with b18b (31flavorscivic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 31flavorscivic &raquo;</TD></TR><TR><TD CLASS="quote">b16
and that stage 4 clutch will in all likelihood break your pedal assembly</TD></TR></TABLE>
stage 4 clutch is such a waste..For only an intake,header,and exhaust?? Get out of here no need for that...New stock replacement or stage 1 is good enough....
you probably will break the pedal depending on what brand it is since the pedal is so damn weak...
and your leg will look like this after 4 months
Old Jul 30, 2006 | 11:18 PM
ls_efhatch's Avatar
Default Re: 1990 civic hatch with b18b (njcrxsi)
well the clutch is kinda worn out its not stiff cause its not new my friend had the motor in his eg hatch with a gsr tranny and it was fine but its been used so it almost fells stock or like a stage 1 or 2 mabey(havent driven a stage 2) im having to use it anyway cause i cant afford another right now so im going to deal with it. its an act im working on upgrades but its slow
Old Jul 30, 2006 | 11:36 PM
E_F_9's Avatar
b16
Old Jul 30, 2006 | 11:45 PM
ls_efhatch's Avatar
Default Re: (MaD_VTAK)
thanks thats what i was leaning towards swap should go in in a couple of weeks i have to get seatbelts ill post up some pics when its running
Old Jul 31, 2006 | 07:54 AM
Contender25
Guest
Posts: n/a
Yeah that **** is gonna be hurtin, and stallin out if you suck at driving and buckin hard when you shift, lol...serious though, there is no need for stage 4 unless you full on race like 500hp at least i would imagine or higher.
Old Aug 4, 2006 | 10:08 PM
ls_efhatch's Avatar
Default Re: (Contender25)
ok well i looked up act clutch the stage 4 is the first stage in there racing type clutch so the stage 4 is really not bad act has up to stage 8
Old Aug 4, 2006 | 10:55 PM
y-49's Avatar
stage 4 is way to much for ur car. and on the tranny it all depends on future plans if ur gonna boost dont get a b16 tranny. get a ls or gsr tranny. my .02 cents
Old Aug 4, 2006 | 11:08 PM
ls_efhatch's Avatar
Default Re: (y-49)
well im on a budget like most people are. im working on boost and full build hoping for 400 hp i got everything planned but i have a ls tranny and thats what im going to mount when i go turbo i dont think the stage 4 will be to much cause its like a stage 1 race clutch but i would go gsr but i would have to do a cabel to hydro conversion and its a pain so im going ls. I even could put the final gear of the ls in the si tranny and have a six speed but thats just an option
vlc92189
Nov 20, 2007 09:05 PM
hbyrd8701
Apr 8, 2007 06:28 PM
jlh22179tx
Nov 6, 2006 02:41 PM
race_that_rex
May 3, 2006 10:25 AM
atfrys
Jul 21, 2005 10:16 AM
