timing belt/chain
I have a 97 accord, 2.2l 4door. was wondering if all the honda engines have belts or do some have chains from the factory? is there any way to tell if belt is going bad? who, where can i get a chain for this engine? any help would be appreciated. this vehicle has about 110,000 mi.
Help
rkrieg4
Help
rkrieg4
theres really no real way to tell if its going bad. and we have belts. the best thing to do is change it at the recomended intervals, which i believe is about 80k. so unless yours was changed at 80k i highly suggest you do it right away
how long have you owned it? If you have owned it since well before 90K miles change that belt asap otherwise when it brakes you will be doing a rebuild on your motor.
You are 20K past due on changing it.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rkrieg4 »</TD></TR><TR><TD CLASS="quote">I have a 97 accord, 2.2l 4door. was wondering if all the honda engines have belts or do some have chains from the factory? is there any way to tell if belt is going bad? who, where can i get a chain for this engine? any help would be appreciated. this vehicle has about 110,000 mi.
Help
rkrieg4</TD></TR></TABLE>
- The S2000 has a chain, all others, belts.
- A timing belt offers little clue as to how close it is to failure, milage is the BEST indicator
- A dealer or http://www.hondaautomotiveparts.com/ , I would not use anything other than OEM for something this crucial, and do the water pump while you are in there.
good luck
Help
good luck
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by conker »</TD></TR><TR><TD CLASS="quote">- The S2000 has a chain, all others, belts.
The k-series engines have chains. So do the civic r-series engines.
I posted a similar question a while ago and got this response
https://honda-tech.com/zerothread?id=1376125
P_Adams posted in the thread so it must be right
But it looks like you are due both mileage wise and time wise and the only real way to check the belt it to take it off and then you should replace it anyways.
"P_Adams posted in the thread so it must be right"
Hondadude responded as well so that is proof its a GREAT thread LOL
Yeah, right, look at his pic. Old gray haired guy, probably goes to bed and dreams about rebuilding carbs. LMAO He probably even knows where the power valve is located
I was wondering when getting a timeing belt if i have to get the 'Timing Belt Tensioner' or "Timing Belt Kit' or if i can just get the timing belt it self and water pump itself.
http://oem.overnightautoparts....false
(planning on getting everything OEM from my dealer just was looking at prices)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hondadude »</TD></TR><TR><TD CLASS="quote"> LMAO He probably even knows where the power valve is located
Does that make me officially old?
</TD></TR></TABLE>Does that make me officially old?
97 accords have more than the 'timing belt and water pump'. You also have the balance belt. shoudl replace everythign while its all open along with the timing belt tensioner, and the balance belt tensioner. And the valve cover gasket set, thermostat, rad cap.
so with everythiing thats about $175 in parts wholesale prices, not including coolant.
faran
Oct 13, 2009 10:33 PM
businessmanph
Feb 2, 2005 03:28 PM
