FS: World Challenge Spec H22 - Complete Swap Minus ECU
Old Apr 23, 2002 | 11:23 AM
Ausmith's Avatar
Default FS: World Challenge Spec H22 - Complete Swap Minus ECU
From 1993 Honda Prelude VTEC. Block serial number is 1000006 - no joke.
Engine had minimal usage in a street car before being prepped for WC use. Since being prepped it has logged only 1500miles and 1 WC race.
Prep included all new bearings, seals, gaskets, valve job, shave/deck, timing belt, water pump, oil pump, balance,blueprint, full port and port match
Comes with:
-Limited Slip Diff
-Cam gears
-New (in the bag) engine wire harness
-All mounts
-Axles
-overbore TB
-DC ceramic header
-Does NOT include ECU
Compression is in the 11+:1 range. Engine is very clean.
Perfect for that killer swap or a WC car.
If interested please contact Dan at 262-375-3989. Located neat Milwaukee, WI.
Old Apr 23, 2002 | 12:50 PM
Ausmith's Avatar
Default Re: FS: World Challenge Spec H22 - Complete Swap Minus ECU (Ausmith)
TTT
Old Apr 25, 2002 | 08:11 AM
Ausmith's Avatar
ttt - again!
Old Apr 25, 2002 | 08:47 AM
Allstar's Avatar
New User
will you part out the tranny?
Old Apr 25, 2002 | 10:40 AM
Ausmith's Avatar
Default Re: FS: World Challenge Spec H22 - Complete Swap Minus ECU (2.2 guy)
If interested please contact Dan at the number listed above.
Old Apr 27, 2002 | 05:27 AM
Civic_Sista's Avatar
TTT - Come on folks.
Old Apr 28, 2002 | 08:06 AM
Ausmith's Avatar
Default Re: FS: World Challenge Spec H22 - Complete Swap Minus ECU (Civic_Sista)
TTT
Old May 1, 2002 | 05:23 AM
anyone?
Old May 2, 2002 | 01:23 PM
Ausmith's Avatar
uP AGAIN
Old May 2, 2002 | 04:55 PM
ITR632's Avatar
maybe if you put a price
Old May 3, 2002 | 04:01 AM
Ausmith's Avatar
Default Re: FS: World Challenge Spec H22 - Complete Swap Minus ECU (ITR632)
$3,500 but you need to call Dan and talk to him. It may go for less.
That's about $5,000 worth of work plus a motor for $3500....
Old May 4, 2002 | 07:26 AM
gefiltefish's Avatar
I think I will sell it first I have CSi covered so its up to you here!
Old May 4, 2002 | 10:27 AM
Ausmith's Avatar
Default Re: FS: World Challenge Spec H22 - Complete Swap Minus ECU (gefiltefish)
Here are pics of the motor...
Old May 4, 2002 | 11:41 AM
phildeez's Avatar
is the engine tuned (meaning just install and drive)? and will it run at full potential with a stock h22a ecu?
Old May 5, 2002 | 07:44 AM
Ausmith's Avatar
Default Re: FS: World Challenge Spec H22 - Complete Swap Minus ECU (phildeez)
It was tuned with a stock H22 ECU.
Fuel, timing, and cams were adjusted during tuning.
No special ECu required. Totally streetable.
00b18b
Mid-Atlantic (Sales)
10
Mar 2, 2014 08:23 AM
godzhand
May 19, 2011 07:56 PM
vick2121
May 18, 2010 07:53 AM
HondaBoy954
Feb 25, 2010 05:19 PM
99B16Si
Nov 1, 2004 10:03 AM
