92 accord Tape deck questions
Old Jul 30, 2006 | 09:11 PM
KillerElfboy's Avatar
Default 92 accord Tape deck questions
Hey, i have two questions about a stock tape player in a 4th gen accord
1. The button illumination on one side of the tape player is out so i cant see half the buttons come night time. Is there a way to replace the bulbs in the tape deck? If not, will a 5th gen tape deck match up with my car harness wise/
2. Whats the best way to hook up a subwoofer and amplifier with the stock head unit? i know of a few ways like going through the ignition wire but im sure theres a safer way
Modified by KillerElfboy at 10:52 PM 7/30/2006
Old Jul 30, 2006 | 09:47 PM
thatasiankidtony's Avatar
Default Re: 92 accord Tape deck questions (KillerElfboy)
Hey, best bet if your planning to run a sub you should get a new headunit. If your really wanna hook it up to your stock headunit you'll need a RCA converter thing. Not sure what the name is. Normally people tap into the rear speakers. You can find alot more information at http://www.installdr.com
Rca thingy
Old Jul 31, 2006 | 12:05 AM
Black Ex Coupe's Avatar
Default Re: 92 accord Tape deck questions (thatasiankidtony)
A 5th gen and 4th gen should share the same harness, but if you can just go with an aftermarket deck. If you insist on using the oem deck then to wire up the sub use the RCA convertor thing which is called a line output convertor
Old Jul 31, 2006 | 07:44 PM
HondaTuner4267's Avatar
Default Re: 92 accord Tape deck questions (Black Ex Coupe)
just cruise on into the 21st century and get a CD/MP3 player
Old Jul 31, 2006 | 09:28 PM
Default Re: 92 accord Tape deck questions (HondaTuner4267)
any idea how to change the bulbs out?
Old Aug 1, 2006 | 02:14 AM
Trumpster's Avatar
You pretty much don't. You would have to take the entire thing apart and the bulbs are probably soldered in place, most likely with no part number or any way to figure out what bulb you would need to replace it with. Really more trouble than it's worth. Get an aftermarket stereo, but if you really love the crappy OEM stereo, a 5th gen stock deck should work just fine. The harnesses didn't change until 98 and even then only on some models.
kingrukus
Dec 25, 2012 02:49 PM
MSU2000
Audio / Security / Video
Aug 21, 2010 06:17 PM
beigemonkey
Jan 28, 2007 05:16 AM
Fuster_Cluck
Jun 4, 2006 01:52 AM
paxorion
Jan 18, 2005 12:39 PM
