Can subframe braces be used with SWIFT reinforcement bars
http://www.evasivemotorsports....3-003
here is said sway bar ^^^ I was thinking of getting. Would I even need a subframe brace with this, and if I did, which would fit - if you know.
THanks for the help
THanks for the help
With out knowing the swaybar diameter or stiffness. It's hard to say if you need a reinforcement or not.
It seems like people with 19mm swaybar or softer get away with out any subframe reinforcements.
That is quite an expensive piece and I assume it will look similar to a mugen EK bar or ITR bar.
tinkfist
11
Jan 28, 2003 01:58 PM
