Pic request: Drop with Koni yellows on lowest perch
y?
just imagine any normal spring and imagine it about an inch lower..
if you're really picky about things, then you'll want the neuspeed koni's. they have 5 grooves instead of 3, so you'll have more flexibility to find your preferable ride height.
if they do, then it'll be lowered somemore on coilover sleeves. You just want to see how it looks?
if the spring doesn't matter, then you'll get different drop heights. That's why I ask what you want to see?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by oldschoolDA9 »</TD></TR><TR><TD CLASS="quote">oh ok, well does anyone actually have this setup?</TD></TR></TABLE>
yes I do,
and it's just like integraxtc said,
lowered more on sleeves.. so the ride height is just what it is,
has nutn to do with the konis
yes I do,
I emailed koni about using the lower perch with some lowering springs and they said not to do it because the springs were not designed for it.
I am wondering what could it be used for because stock springs aren't designed for it either.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gramsilightz99 »</TD></TR><TR><TD CLASS="quote">Koni yellows arent made for dumped ridin morons, keep that in mind. Buy some ****** omni power for that.</TD></TR></TABLE>
koni yellows+ground controls > omni
reno96teg
Jan 12, 2006 09:18 AM
EK k kay
Nov 23, 2005 08:57 PM
alwaysoverkill
Suspension & Brakes
Oct 31, 2005 07:22 PM
b18c4door
Oct 9, 2003 09:01 PM
