should i leave my RSX in gear when parked?
Old Jul 30, 2006 | 11:33 AM
mraza's Avatar
Default should i leave my RSX in gear when parked?
hi, some one told me not to leave my car in gear when it is parked or it will ruin the transmission!!! without putting the e break ... is that true???? is it bad for the car if u do this too often????
thanks
Old Jul 30, 2006 | 11:48 AM
BoBoChan's Avatar
Default Re: should i leave my RSX in gear when parked? (mraza)
Leave it in gear, I do both gear and e-brake.
Old Jul 30, 2006 | 12:31 PM
Turn or Burn's Avatar
It's like a failsafe if your e-brake gives out. But if you are resting the car in gear without the e-brake then it will wear out your tranny.
Old Jul 30, 2006 | 02:51 PM
rsxk24's Avatar
Default Re: (Turn or Burn)
the ebrake is good enough. dont kill your transmission by leaving it in gear or your tranny will die fast. k series trannys are known to fail from leaving it in gear. i work at acura and see it all the time. only use your e brake
Old Jul 30, 2006 | 03:05 PM
BoBoChan's Avatar
Default Re: (rsxk24)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rsxk24 &raquo;</TD></TR><TR><TD CLASS="quote">k series trannys are known to fail from leaving it in gear. i work at acura and see it all the time. only use your e brake</TD></TR></TABLE>
serious?
Old Jul 30, 2006 | 03:53 PM
Flexmyrex's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rsxk24 &raquo;</TD></TR><TR><TD CLASS="quote">the ebrake is good enough. dont kill your transmission by leaving it in gear or your tranny will die fast. k series trannys are known to fail from leaving it in gear. i work at acura and see it all the time. only use your e brake</TD></TR></TABLE>
if you knew anything about the internal construction of a transmission you would not say this. Please tell me what exactly will kill the transmission by leaving it in gear, that makes no sense. Its always the best thing to leave it in 1st or R when parked on a hill in case e-brake fails and NO it will not damage your trans
Old Jul 30, 2006 | 04:33 PM
PGHDC5's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rsxk24 &raquo;</TD></TR><TR><TD CLASS="quote">i work at acura and see it all the time.</TD></TR></TABLE>
cashier counter?
lot attendant?
Old Jul 30, 2006 | 05:27 PM
pat.ter.rick's Avatar
Default Re: (PGHDC5)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PGHDC5 &raquo;</TD></TR><TR><TD CLASS="quote">
cashier counter?
lot attendant?
i say hes a janitor at Acura.
my dad is a great auto technician and works at a shop that is rated the #1 auto shop in the bay area. and he said the safe thing to do is to leave it in gear when/if the e-brakes fail. if it will damage the tranny for leaving it in gear, my dad wouldn't have told me to leave it in gear when i park.
Old Jul 30, 2006 | 06:26 PM
giff74's Avatar
Default Re: (pat.ter.rick)
You want to put on the e-brake first and then leave the car in gear in case the e-brake would fail. I have always felt the trick is not to rest the car on the tranny. Let the brakes hold the weight of the car.
Old Jul 30, 2006 | 07:43 PM
ScuDC5's Avatar
holy mother of misinformation in this thread.
Old Jul 30, 2006 | 08:24 PM
Coldth1's Avatar
right......
Old Jul 30, 2006 | 08:39 PM
.Ry's Avatar
.Ry
Default Re: (ScuDC5)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by giff74 &raquo;</TD></TR><TR><TD CLASS="quote">You want to put on the e-brake first and then leave the car in gear in case the e-brake would fail. I have always felt the trick is not to rest the car on the tranny. Let the brakes hold the weight of the car.</TD></TR></TABLE> This is the best way folks.
Old Jul 30, 2006 | 10:39 PM
reset2k's Avatar
Default Re: (giff74)
Old Jul 31, 2006 | 08:40 AM
Todd00's Avatar
I said I don't want a title!
/end of thread.
ej1252
Sep 18, 2008 09:23 PM
blackk20dc5
13
Jul 1, 2008 08:39 PM
shawn_crx
Jun 29, 2005 11:18 AM
Jake
13
Mar 11, 2004 11:33 AM
ITR1071
May 7, 2003 09:00 PM
