Alignment on Tuesday-Recommendations?
Old Jul 30, 2006 | 10:40 AM
Arsenal's Avatar
Default Alignment on Tuesday-Recommendations?
Booked in for an alignment on tuesday, and was wondering if any of you have suggestions for toe.
The car is used as a daily driver with often spirtied driving. Also alot of driving on the highway, so something not to fidgety, but alittle aggressive.
Any suggestions, and what are the stock settings for the ITR?
Thanks
Old Jul 30, 2006 | 10:51 AM
migs's Avatar
Default Re: Alignment on Tuesday-Recommendations? (Arsenal)
Keep it in specs. No need for a custom alignment for the street.
Old Jul 30, 2006 | 11:04 AM
Arsenal's Avatar
Default Re: Alignment on Tuesday-Recommendations? (migs)
Do you happen to know the stock specs?
Old Jul 30, 2006 | 11:06 AM
itr1244's Avatar
shop should have them no?
Old Jul 30, 2006 | 11:11 AM
migs's Avatar
Front Toe: 0.04 to -0.04 (get it in ZERO)
Front Camber: I believe is -0.5 to -1.5
Rear Toe: 0.00 to 0.10 (get it at 0.04-0.05)
Rear Camber: I believe is -0.5 to -1.5
But yeah, the shop will have the specs. More than likely they will use a Hunter DSP400.
Old Jul 30, 2006 | 04:56 PM
uNF$@#!'s Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by migs &raquo;</TD></TR><TR><TD CLASS="quote">Keep it in specs. No need for a custom alignment for the street.</TD></TR></TABLE>
Old Jul 30, 2006 | 06:39 PM
tommymoose's Avatar
Default Re: Alignment on Tuesday-Recommendations? (uNF$@#!)
I liked the quickness in steering response that a total of 1/16 of toe in the front and 0 in the back gave me. Its great for autocrosses (actually on the mild side of autox toe specs) and doesn't wear the tires badly on the street... I recommend it. Although you also can't go wrong with the factory specs, it makes it a little bit more fun
riceforlife
Suspension & Brakes
Dec 27, 2007 04:54 PM
virginia_dude
Feb 25, 2004 08:54 AM
deviant1
Dec 10, 2003 07:25 AM
1.7na
Mar 20, 2003 03:22 PM
Reid
Jul 5, 2002 01:24 PM
