OBD1 - 4 Wire o2 Sensor to ECU
Old Jul 30, 2006 | 07:56 AM
HondaFerris's Avatar
Default OBD1 - 4 Wire o2 Sensor to ECU
Ok here's the deal. Ive got a 93 OBD1 LS Motor in my 89 std hatch. I've done all the other obd0-obd1 conversions except for the 4 wire o2 sensor. My obd0-obd1 conversion harness did not come with the o2 sensor hookup. Where do i hook them up at the ECU? I un-loomed the o2 sensor plug from my spare LS harness so ive got the plug with plenty of wire to hook up to the ECU. My question is where do these 4 wires hook up?
White ----------------> Pin?
Orange/Black -------> Pin?
Green/White --------> Pin?
Yellow/Black --------> Pin?
Old Jul 30, 2006 | 07:57 AM
Default Re: OBD1 - 4 Wire o2 Sensor to ECU (HondaFerris)
Also would not having this hooked up prevent my car from starting? It hasnt started yet since the swap and I was just wondering if this could be the culpret? Any help is greatly appreciated.
Old Jul 30, 2006 | 08:57 AM
dr_latino999's Avatar
This is what I did for my O2 sensor -
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by me &raquo;</TD></TR><TR><TD CLASS="quote">Ok, ladies and gentlemen, boys and girls, I have fixed the Oxygen sensor heating issue. For the record, this is the correct destination for the wires at the oxygen sensor plug and their destinations with the harness-
Orange/Black - Heater (ECU A6)
Grey(WHITE) - Signal (ECU D14)
Yellow/Black - Injector 12 Volt
Green/White - Ground
Oxygen Sensor Proper, to the plug
Orange/Black --&gt; Black
Grey(White) --&gt; White
Yellow/Black --&gt; Black
Green/White --&gt; Green</TD></TR></TABLE>
https://honda-tech.com/zerothread?id=1319235
Old Jul 30, 2006 | 09:08 AM
Default Re: OBD1 - 4 Wire o2 Sensor to ECU (dr_latino999)
Hey thanks a lot!
Old Aug 5, 2014 | 08:13 AM
gabrielsousa's Avatar
o2 sensor ground on obd1 pinouts is D22
can i connect the o2 sensor ground on ( A23 or A26 or B2 ) ?
Old Aug 5, 2014 | 09:05 AM
4drEF's Avatar
Keyboard Humorist
Why would you even do that? just hook it up to D22 just like you know you should.
You replied to 5 threads that have been inactive for over a year and none even talk about the issue that you are working on.
Next time consider starting your own thread - just one post that directly addresses your question.
jDMJeRk
Oct 3, 2019 08:19 PM
BlackCivicEX
29
Jan 21, 2011 07:19 AM
Ls1 FD3s
Aug 27, 2007 06:44 PM
Hondamonster
12
Jun 21, 2007 08:19 PM
PhatwhipsJDMkits
10
Nov 11, 2004 06:38 AM
