Which One Do You Pick?
cant comment on lca's.
for camber kit up front i use progress. it doesn't replace the entire control arm like most. it uses the stock control arm, just it replaces the ball joint. The ball joint is then turned to adjust camber. It doesn't have the large adjustment range that control arm style camber kits do, but it does the trick. The other plus side is that is also doesn't really interfear with the shock tower like control arm camber kits can.
azn_outlaw
Jan 19, 2002 05:03 AM
