A couple ?'s about DPFI to MPFI and what head and dist. do i have?
I want to do a DPFI to MPFI swap on an 88 CRX DX, but i need to a couple of things about my motor because i think the prior motor was taken out before i got and whoever had it before me got it running, and yes i did do a SEARCH but does not help out my particular situation and could not get a clear answer.
Question#1:My Head has a stamp of PM 3-7, what head do i have?
(when i did search the closest answer i got was a D16A6 Head, is this true?)
Question#2:What Dist. do i have? And will it work with a MPFI swap?
Question#3:My block is D15B with 1669502 underneath, is it USDM or JDM?
Question#4:My friend gave me an HF head with IM, can i use it?
(i'm guessing i cant because it's HF and redline at like 5000rpm)
Thanks!
Thanks!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Magick211 »</TD></TR><TR><TD CLASS="quote">If you are running dpfi right now then your current distributor is not gonna work with the mpfi swap.</TD></TR></TABLE>
Thank you sir for that answer!Now i know.
d15dood
Jan 8, 2003 08:45 AM
