Help! clutch pedal sinks to the floor and wont go back up!
Old Jul 29, 2006 | 02:23 PM
707EF8's Avatar
Default Help! clutch pedal sinks to the floor and wont go back up!
i have a 1994 Del Sol. this morning i tried to drive my car but it wouldnt shift into gear when i depressed the clutch pedal. so i looked into clutch master resivoir and found it needed new fluid cuz it was dark. started to bleed the clutch master cylinder by loosening the bleed screw and then i put some new fluid into clutch cylinder, went to depress the clutch pedal but all it did was sink down to the floor and it did not go back up. i filled up the clutch system but the pedal wont move. I cant put the car into any gears. please help. any suggestions will help.
Old Jul 29, 2006 | 02:25 PM
philosofy1's Avatar
Default Re: Help! clutch pedal sinks to the floor and wont go back up! (707EF8)
you have a bad master cylinder and needs to be replaced.
Old Jul 29, 2006 | 02:50 PM
Targa250R's Avatar
be professional
Default Re: Help! clutch pedal sinks to the floor and wont go back up! (philosofy1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by philosofy1 &raquo;</TD></TR><TR><TD CLASS="quote">you have a bad master cylinder and needs to be replaced. </TD></TR></TABLE>
It is a good practice to replace both the master and slave cylinders at the same time as preventative maintenance. Typically, when one goes bad, the other will **** the bed shortly thereafter.
Old Jul 29, 2006 | 02:51 PM
philosofy1's Avatar
Default Re: Help! clutch pedal sinks to the floor and wont go back up! (Targa250R)
good point, totally forgot about the slave cylinder.
Old Jul 29, 2006 | 07:56 PM
sauceja's Avatar
Yep the manual says that a pedal that goes to the floor can be caused by Master Cylinder, Slave Cylinder or throwout bearing or damaged shift fork.
Can also be caused by air in your system. I just had my run-in on hydro tranny's last week after my engine swap on an accord wagon.
Old Jul 29, 2006 | 08:05 PM
707EF8's Avatar
Default Re: Help! clutch pedal sinks to the floor and wont go back up! (sauceja)
found out why.. i didnt bleed the system correctly. i feel stupid now.
Old Jul 29, 2006 | 08:32 PM
Syndacate's Avatar
air in teh system, eh? Eh, **** happens O.o
Least u got awway with not buying a new MC and SC
reenie10_73
Jan 28, 2010 08:40 PM
sibious
Jun 13, 2008 03:53 PM
707EF8
Jul 29, 2006 08:09 PM
DriveSideWays
Jul 4, 2004 05:07 AM
Mr.Armani
Jun 3, 2003 08:10 PM
