name that injector
Old Jul 29, 2006 | 12:01 PM
abnaasefmb's Avatar
Default name that injector
I just got these; they are supposed to be 580cc. I just want to make sure before I throw them in. only marking on them is; 10350/4615
Thanks
Old Jul 29, 2006 | 01:02 PM
SL0WEGG's Avatar
Default Re: name that injector (abnaasefmb)
check the number on top of the injector near the plug. It should have a series of numbers. Give us the number or google search it with word injector.
Old Jul 29, 2006 | 03:33 PM
DRAGLS's Avatar
Default Re: name that injector (boostedej1)
those numbers you are giving are not checking out.
Old Jul 29, 2006 | 04:25 PM
abnaasefmb's Avatar
Default Re: name that injector (DRAGLS)
my bad. 5135 17113841
Old Jul 29, 2006 | 04:55 PM
nebulight's Avatar
Bump because I want to know too. I have injectors that look EXACTLY like that, but I have different part numbers around the rim:
Three of them say 1065 17113744, one of them says 1173 17113742!
Also, I was told these would fit the stock fuel rail. Will they?
I'm kinda pissed because I got these injectors from a well respected sponsor. I just found out tonight from this thread (thank you), so we will see how they react to my PM I just sent.
Old Jul 29, 2006 | 05:01 PM
tony1's Avatar
Default Re: name that injector (nebulight)
There are a lot of different size injectors that look identical to that, can't go by what they look like. Depending on where they came from, sometimes they're engraved on the body.
Old Jul 29, 2006 | 05:06 PM
abnaasefmb's Avatar
Default Re: name that injector (tony1)
here is what the injector side looks like, any one at lest know what brand?
nebulight's Avatar
Well, I found out that three are 1008cc and the other is 785cc!!!!!!
http://www.fiveomotorsport.com...S.asp
Old Jul 29, 2006 | 05:07 PM
nebulight's Avatar
They are Rochester injectors You're injectors aren't coming up... double check your part number maybe?
Old Jul 29, 2006 | 07:04 PM
boosted k20's Avatar
yup those are rochester injectors. The shop where i work is a dealer for those injectors. the numbers on the top of the injectors will let u know what kind they are. but u already found out too bad it sucks u got 3 1000cc and 1 785cc
Rochester injectors are the same injectors Precision sells...... except precision puts a pretty sticker on it
Old Jul 29, 2006 | 07:13 PM
SL0WEGG's Avatar
Default Re: name that injector (boosted k20)
for some reason i cannot find a rochester 580cc injector although precision has one???
Old Jul 29, 2006 | 07:23 PM
nebulight's Avatar
Did you double check your part number?
Old Jul 29, 2006 | 07:26 PM
nebulight's Avatar
Also, are these injectors going to fit my stock fuel rail?
Old Jul 29, 2006 | 08:26 PM
abnaasefmb's Avatar
i search gm part # and came up with this, does it sound right?
Part Number 17113841 (OE # 25324744)
Static Flow Rate @ 43.5 PSI (300KPa)
55.0 lb/hr / 6.9 gm/sec / 578 cc/min
Static Flow Rate @ 58.0 PSI (400KPa)
63.5 lb/hr / 7.97 gm/sec / 667 cc/min
Dynamic Flow Rate @ 43.5 PSI = 1.34 gm/pulse
2.5ms pulse width and 10ms repetition rate
Coil Resistance: 2 Ohms / Low Impedance / Low-Z
(Peak-hold ECM driver modifications required)
Cone Spray Angle - 20.3 degrees - single spray cone.
Approximate cone angle for 90% of spray volume
Additional Information:
- Silicon grease supplied to lubricate o-rings prior to installation
- Ball & seat design with 6-hole diffuser disc. Same as MSD and Holley product.
Old Jul 29, 2006 | 09:15 PM
mtber's Avatar
Those injectors look just like precision's injectors :-)
Old Jul 30, 2006 | 04:10 AM
BoostedEG6's Avatar
Default Re: name that injector (mtber)
they look just like my Precision 1000cc's
Old Jul 30, 2006 | 04:29 AM
RTW DC2R's Avatar
the housing/color look like precisions to me as well, not sure what size
Old Jul 30, 2006 | 05:24 AM
SL0WEGG's Avatar
Default Re: (RTW DC2R)
i guess delphi makes these's and that look just like the rochester
edit: while doing a search they seem to be the same company??
Old Jul 30, 2006 | 05:32 AM
RTW DC2R's Avatar
when I ordered injector clips directly from Precision, they told me the clips come from Delphi so its probably all the same **** lol
Old Jul 30, 2006 | 10:48 AM
Precision injectors = Rochester Injectors minus the fancy precision sticker and the increased price
on some of the rochester injectors, u might need to shave the top plastic peice right under the O-Ring. its sometimes thicker than what can fit in the fuel rail. u need to make them "import style" instead of "domestic style". i dremel tool can take care of that easily
Old Jul 30, 2006 | 12:21 PM
rwcdrums's Avatar
Default Re: (boosted k20)
yeah my precision 880's look like those
Natural Aspirations
Aug 14, 2009 04:16 PM
lovey408
Sep 22, 2007 08:24 PM
URNVS
Jul 1, 2006 03:41 PM
servion
Feb 1, 2004 02:05 PM
fastludeh22
Oct 13, 2003 07:05 AM
