Dual over head cam on a d16z6
Yes!
All you have to do is remove all the oil form your engine then drive it very hard, then reset your ECU and pop your hood and you should have a B16 head on your D16 block. Or you can go with the Ecotec swap. Either one will net you 763 WHP and 441FT TQ at the wheels.
Im just kidding
Its not possible and just go with a B-Series swap
http://www.hmotorsonline.com
Im just kidding
no there isn't...and those other ********* talk a lot of ****..i bet u do think u can really put an ecotec head on a d series don't ya...man YOU SUCK!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by stock_honda_coupe »</TD></TR><TR><TD CLASS="quote">Is there a head swap I can do on my engine so that I can have a DOHC Vtec D series engine?</TD></TR></TABLE>
if you plan on replacing the internals just get an LS swap. no point in building a D if you cant afford a B. building the D is for people that have the money for a B but want to be differant.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by stock_honda_coupe »</TD></TR><TR><TD CLASS="quote">I was just wondering because the Bseries engines are expensive and I plan to replace most of the internals anyways.</TD></TR></TABLE>
No you cant do the swap.. your into cars man.. **** isnt cheap if you wanna play u gotta pay
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ej8luver »</TD></TR><TR><TD CLASS="quote">no there isn't...and those other ********* talk a lot of ****..i bet u do think u can really put an ecotec head on a d series don't ya...man YOU SUCK!</TD></TR></TABLE>
I like how you back him up and then tell him that he sucks.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 99FBPSi »</TD></TR><TR><TD CLASS="quote">I like how you back him up and then tell him that he sucks.</TD></TR></TABLE>
Seriously, I was like WTFMATE?!
lmfao at this thread...
just turbo the d.. it will cost u a total of about 800-1200 if u know where to go and have hookups.. thats tuned also.. hmt kit
or get a ls swap if u want 2 cams...
but my 1's better than ur 2
Wow, what a bunch of ******s.
You can put a ZC head onto your D15/D16. That'll make it a DOHC D series.
Other than the ZC head your only other option is to swap in another motor.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Everyones Hero »</TD></TR><TR><TD CLASS="quote">
Other than the ZC head your only other option is to swap in another motor.</TD></TR></TABLE>
nope
nope
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 24TEN »</TD></TR><TR><TD CLASS="quote">nope</TD></TR></TABLE>
ZC won't fit a D16 block?
Why not?
Why not?
it's different. i had this same question before a long time ago. i had lots of questions before and after i bought my DOHC ZC. it shares alot of parts with the older integra 1.6 DOHC motor, and you can swap alot of different rods/piston combos from pretty much all D-Series engines, but that's pretty much where most of the similarites end. the bulk of the motor which is the block and head are different than all other honda motors, so the DOHC ZC head will not fit on a regular D-Series block, it wouln't even fit on SOHC block that is stamped ZC. The head and block are specific to eachother.
Sorry it was a h head on a f23 bottom. Called G23
https://honda-tech.com/zerothread?id=1069869
https://honda-tech.com/zero...age=1
https://honda-tech.com/zerothread?id=776837
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cambopheonix56 »</TD></TR><TR><TD CLASS="quote">I read somewhere on hear some one put a b series head on a d series block. Obviously its not a direct swap.</TD></TR></TABLE>
heard that one too. never seen it though. i've also heard that someone did a B16A head on a DOHC AC block, again never seen it.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 24TEN »</TD></TR><TR><TD CLASS="quote">it's different. i had this same question before a long time ago. i had lots of questions before and after i bought my DOHC ZC. it shares alot of parts with the older integra 1.6 DOHC motor, and you can swap alot of different rods/piston combos from pretty much all D-Series engines, but that's pretty much where most of the similarites end. the bulk of the motor which is the block and head are different than all other honda motors, so the DOHC ZC head will not fit on a regular D-Series block, it wouln't even fit on SOHC block that is stamped ZC. The head and block are specific to eachother.</TD></TR></TABLE>
Thanks. I learned something new today.
cool
but to be completely honest, if someone really wanted a DOHC ZC head on a D-Series block, any talented machine shop can make it happen LOL HAHAHAHA But yeah, it won't bolt up.
</TD></TR></TABLE>cool
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDMlyfestyle »</TD></TR><TR><TD CLASS="quote">
No you cant do the swap.. your into cars man.. **** isnt cheap if you wanna play u gotta pay</TD></TR></TABLE>
A-MEN!!
A-MEN!!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 24TEN »</TD></TR><TR><TD CLASS="quote">cool
but to be completely honest, if someone really wanted a DOHC ZC head on a D-Series block, any talented machine shop can make it happen LOL HAHAHAHA But yeah, it won't bolt up.</TD></TR></TABLE>
For the cost to take it to a machiene shop to have them make it work it would probably be faster & cheaper to just go get a complete swap.
but to be completely honest, if someone really wanted a DOHC ZC head on a D-Series block, any talented machine shop can make it happen LOL HAHAHAHA But yeah, it won't bolt up.</TD></TR></TABLE>For the cost to take it to a machiene shop to have them make it work it would probably be faster & cheaper to just go get a complete swap.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by siregcivic »</TD></TR><TR><TD CLASS="quote">lmfao at this thread...
but my 1's better than ur 2</TD></TR></TABLE>
actually i turboed my old d for $300, tuned, intercooled, 550cc injectors, chrome, there are ways my friend. oh and i didnt steal any of it haha.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cambopheonix56 »</TD></TR><TR><TD CLASS="quote">Sorry it was a h head on a f23 bottom. Called G23
that is crazy, but thats also an H and F series. thats for the accords n preludes.
but if you did put the h23 on the f 23 bottom would you be able to mount it in a civic? wouldnt the mounts be different? cause your bottem end is still from an accord?
kudos to the guy who did that swap,
and then boosted it
and then boosted it
