Type R Front Sway Bar
ITR or CTR?
according to this jdmuniverse writeup either will work
for the ITR you would need 96-00 ex/hx front lca's since those are fitted to accept a sway bar, the bar itself and appropriate D-brackets/bushings, and the endlinks from the bar you use.
for the CTR you would need the 99-00 SI front lca's as the si and ctr use the same front endlink design, different than the one on other civics of those years. you would again need the bar, and appropriate bracketry, as well as the CTR or si endlinks.
one note though, are you asking about usdm or jdm ITR front bar? usdm itr and usdm gsr are the same bar diameter, possibly the same bar completely. the gsr just doesnt have the power of the arrrrrr though.
jdm ITR is a larger front bar, 25mm instead of the 24mm of usdm gsr/itr.
BLUE EH3
13
Jun 8, 2005 06:18 PM
