Help! Spongy Brakes?
Old Jul 29, 2006 | 05:32 AM
hurrcane201's Avatar
Default Help! Spongy Brakes?
I just bought a 95 accord ex. The brakes a real spongy, they go all the way to the floor. I bled all four wheels and it seemed to fix it, but after about a half hour of driving, they turned spongy again. I did not see any leaks around the master cylinder or wheel cylinders, nor was the brake fluid low, I did not see or hear any noticible vacum leaks. What could be causing this?????????
Old Jul 29, 2006 | 06:05 AM
BLKFLSH's Avatar
Default Re: Help! Spongy Brakes? (hurrcane201)
The "master cylinder" is leaking internally. You will not see the brake fluid come out. This is a common condition, when the brake fluid is not changed regularly. Brake fluid absorbs moisture (in the air, or wherever). This moisture makes internal parts rust (rust tears up the seals). The brake fluid should be changed every 30,000 miles or 3 years (I think).
Old Jul 29, 2006 | 07:10 AM
Officer's Avatar
Default Re: Help! Spongy Brakes? (BLKFLSH)
BLKFLSH is right on the money, just take care of that and you should be ready to go. I had the exact same problem on my 91 accord. good luck man
Old Jul 29, 2006 | 08:01 AM
Stew Pidasso's Avatar
Default Re: Help! Spongy Brakes? (TotaledHatch)
Master Cylinder is an easy replacement on that car. Good luck man.
Old Jul 29, 2006 | 09:33 AM
Default Re: Help! Spongy Brakes? (Stew Pidasso)
Thanks everyone for all your help and a really quick response. I really appreciate it. I am on my way to get a new master cylinder!
Bob
Old Aug 1, 2006 | 07:04 PM
Officer's Avatar
Hey man no prob stay a member its a huge help when you have a honda
PhilE2212
Suspension & Brakes
Nov 7, 2012 10:08 AM
PhilE2212
Nov 2, 2012 08:26 PM
jdmsteve2004
May 31, 2004 12:20 AM
ib69nu
Apr 2, 2003 06:19 AM
wra10s
Aug 31, 2001 06:22 AM
