00 B16 TRANSMISSION GONE WRONG
Old Jul 29, 2006 | 01:06 AM
2mansi's Avatar
Default 00 B16 TRANSMISSION GONE WRONG
ok guys my clutch was going out and i decided to replace it. Right before i figure the transmission was going out though i was having a problem acclerating when in reverse. I would travel about 1 ft and then it would seem like the car would stop as if the axle was popped out. Checked to see if it was the axle and it was not. Now when doing this the car would also get stuck in gear. This only occurs while i am in reverse.
i have replaced the clutch as of now and dont know what to look for. Also the tranny is a 2000 b16 hydro...
I thanks in advance!!!!!!!
Old Jul 29, 2006 | 06:49 AM
NJcoupe's Avatar
Default Re: 00 B16 TRANSMISSION GONE WRONG (2mansi)
Sounds like you have a bent shifter fork.
Old Jul 29, 2006 | 05:08 PM
SkRiBLaH's Avatar
Default Re: 00 B16 TRANSMISSION GONE WRONG (dxcoupe.)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dxcoupe. &raquo;</TD></TR><TR><TD CLASS="quote">Sounds like you have a bent shifter fork.</TD></TR></TABLE>
no you ******* idiot!! DO YOU KNOW HOW HARD IT IS TO BEND THE 1/2/R FORK?!!??
anyway you may have a bad reverse idler gear selector.
part number 4 - $25
Old Jul 30, 2006 | 12:54 AM
2mansi's Avatar
HEY DUDE THANKS FOR ALL THE HELP....IS THERE A WAY I CAN CHECK TO SEE IF IT IS BAD....IF SO PLEASE POST HOW
Old Jul 30, 2006 | 07:55 AM
SkRiBLaH's Avatar
Default Re: (2mansi)
yea! open up the trans and take it out!!!
Old Jul 30, 2006 | 08:48 AM
Dat1BVtecN's Avatar
maybe your differential is fawked, take out both axles and look into the hole and see if u can see the differential
Old Jul 30, 2006 | 11:06 AM
2mansi's Avatar
Default Re: 00 B16 TRANSMISSION GONE WRONG (Dat1BVtecN)
Yeah I already checked to see if the differential was there and it is.....I'm taking the tranny out today and going to open it up
Old Aug 1, 2006 | 11:38 AM
1fastVX's Avatar
So what is the verdict on your tranny? What was broken on it? I have the same exact issue as you described. Another guy here also had a similar problem and found that a bearing had cracked apart.
John
Old Aug 1, 2006 | 03:58 PM
2mansi's Avatar
well i saw that the input shaft bearing was scrathed bad so i took it my friends shop...he is going to take it apart and see what the deal is....
Old Aug 2, 2006 | 04:42 AM
1fastVX's Avatar
What do you mean by scratched? Does your issue look anything like in the link below? Let me know what the results are.
https://honda-tech.com/zerothread?id=1622573
Thanks,
John
Old Aug 2, 2006 | 11:17 PM
2mansi's Avatar
na dude it had some scratches from wear and tear but dam that **** looks fucked up on urs...
hope all goes well with the tear down.....thanks for the pics to...
Old Aug 3, 2006 | 02:12 AM
1fastVX's Avatar
No thats not my tranny, though our issue was the same as his. I posted a pic to see if yours looked like that, nut I am guessing yours was not as bad. I stopped driving mine as soon as it happened. I am hoping for minor damage like yours.
John
Old Aug 3, 2006 | 01:58 PM
2mansi's Avatar
Default Re: (1fastVX)
Yeah mine was not that bad.....**** not even close. I actually picked up my transmission today and I will let u know how it turns out when I get it on. I will post pics of what parts were changed also.
2mansi
Jul 29, 2006 12:23 AM
ImThatGuy
Feb 12, 2006 11:46 AM
Vtak DOHCTA
Feb 11, 2006 12:53 PM
Markb16a
14
Oct 16, 2005 08:22 PM
1SlowSi
Nov 11, 2004 01:46 AM
