How many watts in 'real life'?
Old Jul 29, 2006 | 01:05 AM
imadigitalgod's Avatar
Default How many watts in 'real life'?
I have the Kenwood KAC-7201. The specs say that it puts out 460 watts RMS if it is bridged. I know its not CEA certified testing so i am wondering how many watts the amp actually puts out? I have an alpine headunit that says 4v preouts. I am running 2 Infinity 1042w subs (10" dual 4 ohm voice coils. both subs wired to have 8 ohms each, ran in parallel to put the 4 ohm load on the amp)
Old Jul 29, 2006 | 04:14 AM
shyboy817's Avatar
RMS Power at 4 Ohms 150 W x 2
RMS Power at 2 Ohms 230 W x 2
Old Jul 29, 2006 | 07:38 AM
Default Re: (shyboy817)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by shyboy817 &raquo;</TD></TR><TR><TD CLASS="quote">
RMS Power at 2 Ohms 230 W x 2</TD></TR></TABLE>
I used it in bridge mode that 'says' it putsout 460w RMS but usually they dont actually put out that much cuz its very hard to obtain the testing conditions in the car audio environment that they had when they tetsed the amp so im wondering about how many watts was the amp really putting out in bridged position. i wouldnt have the subs up loud at all, just so it would mix well with the regular speakers
Old Jul 29, 2006 | 08:43 AM
fcm's Avatar
fcm
Old Fart
Default Re: (imadigitalgod)
About 300W RMS into 4 ohms @ 14.4V. 94
Old Jul 29, 2006 | 09:50 AM
nsxxtreme's Avatar
Default Re: (fcm)
Take the fuse rating mutiply it by the voltage. This would be the output if the amp was 100% efficient.
50% of that for a class A/B
65-70% for a class D
Is a good guestimate.
Old Jul 29, 2006 | 11:45 AM
ncacuraintegra's Avatar
the ratings on the new kenwood amps are not accurate like the old school kenwoods
Old Jul 29, 2006 | 07:16 PM
Default Re: (fcm)
Will the Eclipse XA1000 that is CEA-2006 compliant, put out 320 into a 4 ohm load? it says it will but im not sure what the CEA-2006 compliant exactly means.
Old Jul 30, 2006 | 08:54 PM
DireFire34's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by imadigitalgod &raquo;</TD></TR><TR><TD CLASS="quote">Will the Eclipse XA1000 that is CEA-2006 compliant, put out 320 into a 4 ohm load? it says it will but im not sure what the CEA-2006 compliant exactly means. </TD></TR></TABLE>
m.glisson003
Audio / Security / Video
18
Aug 15, 2011 06:17 PM
chinkyx90
Mar 14, 2009 05:35 PM
TANKE92113
12
Feb 6, 2007 01:59 PM
weak_tec
Jun 25, 2005 01:09 PM
Supta
Nov 16, 2004 05:59 PM
