Disc Brakes
Old Jul 28, 2006 | 11:51 PM
tambara's Avatar
Default Disc Brakes
I have a 94 honda del sol si i wanna do a engine swap but i know i need a brake upgrade. http://www.tirerack.com/brakes...otors
that would be the website im getting my brakes from. however you can either get 240mm or 262mm which one would be better. DOes it really make a difference if i go with a 240mm. By the way I am putting a b16a2 inside the del sol. I am curious with which why i should go. I dont' plan to race. Can i still brake with the 240mm? Any input would be great.
Old Jul 29, 2006 | 02:50 AM
ejprimo's Avatar
Default Re: Disc Brakes (tambara)
you have a del sol si but that link you provided above is for a del sol VTEC. so just do another seach and get brembo blanks or duralast/valuecraft rotors if you want to save $$. akebono proACT are good steet pads with no squeal and minimal dust.
Old Jul 29, 2006 | 07:33 AM
tambara's Avatar
Default Re: Disc Brakes (ejprimo)
o i know that i have a si but don't i need vtec disc brakes if im doing a bigger engine swap? or it really doesn't matter?
Old Jul 29, 2006 | 07:36 AM
Sleepy_Red_hatch's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tambara &raquo;</TD></TR><TR><TD CLASS="quote">o i know that i have a si but don't i need vtec disc brakes if im doing a bigger engine swap? or it really doesn't matter?</TD></TR></TABLE>
you DO know that its not as easy as simply "slapping" the new rotors on right? if they are bigger then stock, your calipers wont fit over them.
Old Jul 29, 2006 | 07:40 AM
Archidictus's Avatar
Unceasing Measure
No, it doesn't matter at all. Your car will still be slow as hell with a B16A in it, and unless you're going up to 140mph on residential streets you won't need a brake upgrade.
Old Jul 29, 2006 | 07:43 AM
Default Re: Disc Brakes (Archidictus)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Archidictus &raquo;</TD></TR><TR><TD CLASS="quote">
No, it doesn't matter at all. Your car will still be slow as hell with a B16A in it, and unless you're going up to 140mph on residential streets you won't need a brake upgrade.</TD></TR></TABLE>
yup. and you already have the rear discs (cosmetic upgrade) your brakes will be fine. just take it easy and get used to the extra weight for the first few weeks
splashy
Feb 15, 2013 11:03 AM
Sneaky VeeLay
Feb 2, 2011 09:51 AM
eg2jr
Apr 27, 2008 08:39 PM
DelSolMarine
Aug 23, 2007 06:36 PM
samdawgsol
Feb 8, 2002 01:48 PM
