Engine whine after H22A swap and H23 manual tensioner conversion...
Old Jul 28, 2006 | 10:41 PM
hoehouseworker's Avatar
Default Engine whine after H22A swap and H23 manual tensioner conversion...
Just dropped in a JDM H22A into my 96 si, and everything runs great except there is a loud high pitched whine coming somewhere from under the timing belt cover.
The old H23 manual tensioner was swapped onto the H22A, and the new timing belt seems nice and snug. My friend that performed the motor swap said the whine sound could either be the manual tensioner or the oil pump. As far as I know the manual tensioner is good because it worked fine on my H23.
Could the oil pump on the JDM H22A possibly be making the loud whine?
Old Jul 28, 2006 | 11:01 PM
onefastrx7turbo's Avatar
Default Re: Engine whine after H22A swap and H23 manual tensioner conversion... (hoehouseworker)
timing belt too tight?
Old Jul 28, 2006 | 11:14 PM
Default Re: Engine whine after H22A swap and H23 manual tensioner conversion... (onefastrx7turbo)
How would I loosen the timing belt just a tiny bit to see if that helps?
Old Jul 28, 2006 | 11:23 PM
DCFIVER's Avatar
Community Builder
Loved
Community Favorite
more than likely the Balancer belt tensioner. Easy to over tighten.
Old Jul 29, 2006 | 05:13 AM
ludesleep's Avatar
Default Re: Engine whine after H22A swap and H23 manual tensioner conversion... (cb7-R)
did you use a new tensioner bearing or a new one....those bearings make that noise when they are bad
Old Jul 29, 2006 | 09:07 AM
Default Re: Engine whine after H22A swap and H23 manual tensioner conversion... (ludesleep)
I used the old ones, but as far as I know they are good because they didn't make this noise on the H23 before it blew up.
Old Jul 29, 2006 | 09:26 AM
paulwithap's Avatar
mine's been doing the same thing. i just say its supercharged.
Old Jul 29, 2006 | 12:15 PM
ludesleep's Avatar
Default Re: (paulwithap)
Well...if its the bearing then I would replace it...I had one seize up on me and smoked my belt . Since we are on the topic lol has anyone ever takin a Nice(C) bearing or a skate bearing and put an air hose up to it... sounds just like a supercharger lol
Old Jul 29, 2006 | 10:03 PM
paulwithap's Avatar
lol, i'll try it at work tomorrow
jasrams
Jan 8, 2013 02:50 PM
Prelude_5g00
Oct 21, 2012 10:57 AM
Sick'Lude
Dec 7, 2004 10:41 AM
CBR
Sep 1, 2002 04:40 PM
