What factory airbox works with b16a?
Old Jul 28, 2006 | 09:12 PM
NAIIAWAH's Avatar
Default What factory airbox works with b16a?
I noticed the factory Si air box inlet is to small in diamter for teh intake tube of the b16. Is there any airbox that bolts right in? IF not does a 90-93 teg airbox work or will a 92-95 airbox work? I do not want a aftermarket intake.
Old Jul 29, 2006 | 03:47 AM
StorminMatt's Avatar
Default Re: What factory airbox works with b16a? (NAIIAWAH)
There is no other airbox that will bolt in easily. However, if you cut the tube on the airbox shorter, you can use a 1990-1993 Integra intake tube for a very stock looking setup. Just keep in mind that the stock airbox is VERY restrictive and WILL reault in VERY significant loss of HP compared to an aftermarket intake. Believe me, I know. If you are deadset against aftermarket intakes, keep in mind that this is a sacrifice you have to make (along with worse gas mileage).
Old Jul 29, 2006 | 03:52 PM
FIGARILA's Avatar
Default Re: What factory airbox works with b16a? (StorminMatt)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by StorminMatt &raquo;</TD></TR><TR><TD CLASS="quote">There is no other airbox that will bolt in easily. However, if you cut the tube on the airbox shorter, you can use a 1990-1993 Integra intake tube for a very stock looking setup. Just keep in mind that the stock airbox is VERY restrictive and WILL reault in VERY significant loss of HP compared to an aftermarket intake. Believe me, I know. If you are deadset against aftermarket intakes, keep in mind that this is a sacrifice you have to make (along with worse gas mileage).</TD></TR></TABLE>...i have the same setup on my car, is there any way to improve the air flow??? maybe a K & N?
Old Jul 29, 2006 | 04:32 PM
crexer's Avatar
Default Re: What factory airbox works with b16a? (Heron of Alexandria)
how is the stock airbox VERY RESTRICTIVE?
Old Jul 29, 2006 | 04:55 PM
Crx Jimmy's Avatar
I had a spare 90-93 integra airbox laying around and its too bit to fit, if you can find one use a SIR airbox with a k&n
Old Jul 29, 2006 | 06:47 PM
FIGARILA's Avatar
Default Re: What factory airbox works with b16a? (crexer)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crexer &raquo;</TD></TR><TR><TD CLASS="quote">how is the stock airbox VERY RESTRICTIVE? </TD></TR></TABLE>.... i have a DA teg airbox with filter when i compare it to the oem airfilter they look similar in size. .......how is the the stock box restrictive?
Old Jul 29, 2006 | 11:47 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Heron of Alexandria &raquo;</TD></TR><TR><TD CLASS="quote">.... i have a DA teg airbox with filter when i compare it to the oem airfilter they look similar in size. .......how is the the stock box restrictive?</TD></TR></TABLE>
The stock box and filter elements are both VERY small. And the fact that the Integra box is the same size certainly does not make it any better.
aandrewcc
Nov 5, 2009 11:47 AM
team714
Nov 29, 2007 01:31 PM
lion-o
Nov 22, 2007 06:57 AM
bryce-o
11
Oct 3, 2007 07:44 AM
erikiksaz1
Oct 6, 2004 06:24 PM
