launching
Old Jul 28, 2006 | 07:49 PM
RSXTYPES0818's Avatar
Default launching
does anybody know a good way to launch there rsx type s i am having trouble at the track doing so.
Old Jul 29, 2006 | 05:16 AM
importwerks's Avatar
Default Re: launching (RSXTYPES0818)
well, in general, you don't want to give it a lot of gas in 1st gear. Over the years I have learned that you simply have to take it easier in 1st than in other gears b/c you SOO much torque in 1st. I mean, the gear reduction may be like 3:1 in the tranny and then another 3:1 in the final drive (just estimates/guesses). So that's a total of 9:1 gear reduction, which provides for a lot of torque. So my advice is that you sort of feather the gas in 1st gear and be moderate in your take off. Don't rev up really high, then dump the clutch; that is a no no. Then once u get in 2nd, that is where you'll want to floor it. good luck
Old Jul 30, 2006 | 10:28 AM
johnnysample's Avatar
Default Re: launching (importwerks)
3500 rpm is best and feather it out, or if u are on tires, slam it. the prb computer has a *2step* built into of sorts, meaning it has the 5500 rev limiter, and doesnt let u rev into vtec, where wheel hop occurs. 3500, give u time to get traction and get rolling, then hit power at 5700 rpm (vtec)
Old Jul 31, 2006 | 09:16 PM
bliss@5200's Avatar
Default Re: launching (johnnysample)
i go to about 4k everytime. it works real good, ill spin to about 5 or so then it just grabs and engages vtec immeditatly. this is just my preference
Old Aug 1, 2006 | 02:59 AM
taggart_lumpy's Avatar
Default Re: launching (bliss@5200)
personally at 2700 but that was on stock tires im going to do about 3500 now
Old Aug 1, 2006 | 05:31 AM
ScuDC5's Avatar
I've been using 3000. Key is to control the urge to just step on it after dumping the clutch. You want it to grip at 3000 before stepping on it more. I used to always just work like a level-pulley and soon as I dropped it, I'd slam on the gas letting me spin through 4 gears before catching in 5th then shifting back down to 2nd (still got good times!)
Old Aug 5, 2006 | 11:01 PM
Devilboiz's Avatar
i rev at 4rpm and feather the gas until it grab real good then floor it. that is the best way so far
Devilboiz's Avatar
don't forget to lower ur tire pressure down so u can get more traction. it helps
Old Aug 6, 2006 | 06:36 AM
mrnewguy's Avatar
* B A N N E D *
how do u launch actually?
Old Aug 6, 2006 | 07:53 AM
BarracksSi's Avatar
My best 60' times (I'm on street tires at about 20 psi, BTW) came when I kept the revs high and feathered the clutch, keeping the tires just on the edge of losing traction.
I think that there's a little better response when finally letting the clutch out versus stomping on the gas alone. You'd do either one once you know you have traction, but the difference is that the engine takes a split second to respond to an open throttle while the clutch acts pretty immediately.
Old Aug 6, 2006 | 12:23 PM
Blue03RSX's Avatar
What are your mods? I dynoed at 210whp and 160ftlb of torque. I found it works best to ride the clutch of the line at about 4500 and then let it eat. I ended up buying hoosier drag radials and im very pleased
Old Aug 7, 2006 | 08:52 AM
Crank's Avatar
Default Re: launching (Blue03RSX)
^^ wow thats hella trq, what does the motor got?
Old Aug 7, 2006 | 10:33 AM
ON STOCK TIRES ON A 06 RSX TYPES S WHAT SHOULD I LOWER THE TIRE PRESSURES DOWN TO AT THE TRACK.
Old Aug 7, 2006 | 01:12 PM
Blue03RSX's Avatar
its a k and n intake kpro straight cat and tsudo exhaust and a stock header
on 205 55 16 i lower mine 2 18 pounds to prevent wheel hop it still spins but the time is better
Ex-Eg-Driver
Mar 13, 2009 12:25 AM
sp00led
Nov 4, 2008 12:27 PM
Garage786
Jan 15, 2008 04:13 AM
VtecNit01
Jan 11, 2002 09:24 AM
martilafox
Jul 28, 2001 02:13 PM
