my prelude is surging
lol you should have searched...very common problem either a fast idle thermo valve located underneather the Throttle body, sometime its an easy fix by taking it off and screwing a screw that has came lose inside or a idle air control. Also i have even heard worse problems as to having to swap ECUs if all else fails. For instance i pretty sure its my ECU due to the fact that i have swapped motor and it surged with the old motor and also the new motor at the same rate......so let me know
Maple50175
Honda Civic (2001 - 2005)
Nov 18, 2010 05:06 PM
