95 civic no start in morning
Old Jul 28, 2006 | 06:31 PM
95civic420's Avatar
Default 95 civic no start in morning
already changed the coil and main relay, I'm getting spark, battery checked out
good, fuel pump is priming, fuel pressure is dead on, every morning the car
cranks but just doesn't turn over. By mid day the car will start right up like nothing
was wrong with it. WTF could it be???
Old Jul 30, 2006 | 08:12 PM
sneakypete's Avatar
Default Re: 95 civic no start in morning (95civic420)
Bump it up. Help a brotha out.
Old Jul 30, 2006 | 08:13 PM
JDMlyfestyle's Avatar
Might wanna check your timing. timing being off its harder to start a car.
Old Aug 1, 2006 | 05:43 PM
95civic420's Avatar
Default Re: (JDMlyfestyle)
timing checked out good. Sometimes when i'm driving my fuel gauge will shoot up past full but I know I just have half a tank. Is that the gauge messing up or the float? Also heard that fuel pump check valve might be sticking allowing pressure to drain back to the pump causing a no start. How do I check that?
Old Aug 1, 2006 | 05:48 PM
BLUE EH3's Avatar
Help we my pennies
Old Aug 1, 2006 | 05:50 PM
byronl's Avatar
how's your fuel filter? i had the exact same symptoms then after i changed the fuel filter it was all good.
Old Aug 2, 2006 | 06:10 PM
95civic420's Avatar
Default Re: 95 civic no start in morning (byronl)
I changed my fuel filter about 8 months ago. I'm thinking of testing the system for fuel volume. I tested for pressure and I got about 36 during idle and when I gunned it I got 41. I also checked for pressure when the car didn't start. With key on engine off I got 40 and when I cranked it I got around 43. Does anyone know the specs for fuel volume and how to test for it?
smileygreasy
15
Apr 19, 2015 07:36 PM
weaponsgrade
Jan 8, 2010 09:55 AM
Pr0ject93hb
Feb 25, 2007 08:34 AM
accord-h22
Feb 13, 2007 04:45 PM
ewing86
Oct 20, 2004 04:35 PM
