AC help in HOT OL TEXAS
Old Jul 28, 2006 | 04:18 PM
speedaddict's Avatar
Default AC help in HOT OL TEXAS
I'm working on my mother in laws 98 Accord. The AC cuts off and on (mostly off) I noticed that the fans would cut off and on. So I tried to check the relays under the hood. They all seem ok BUT here's where it gets weird this blue and red striped wire hooked up to the (whatever its called in the picture), when I poke the test light to it, the fans turn on and the ac stays on...any ideas?
Old Jul 28, 2006 | 07:54 PM
v4lu3s's Avatar
RTFM
that is the pressure cut off switch. I beleive its either high presusre or a 3 way where it will cut the ac off if pressure is too low or too high.
Old Jul 28, 2006 | 08:02 PM
Superorb's Avatar
nest thing to do: connect an a/c line pressure guage that you can get at walmart or any automotive store like autozone to the LOW PRESSURE side only. That will tell you the charge state(pressure) of your a/c system. remember to have the a/c on full blast recirculate to get a correct reading.
Old Jul 28, 2006 | 09:23 PM
Honda-Master's Avatar
Default Re: AC help in HOT OL TEXAS (speedaddict)
sounds like a lack of ground .........when you are hooking up the test lite to the red/blue wire you are giving ground to the system .....
DO not waste your time checking the pressure ,, most likely you got a bad
thermostatic switch located in the evaporator
Old Jul 29, 2006 | 06:16 AM
Default Re: AC help in HOT OL TEXAS (Honda-Master)
Well, after reading this, it sounds like the pressure switch is cutting off and on. So this could be the low freon? Low freon could be that its leaking? OR this can be a bad switch...
Old Jul 30, 2006 | 04:42 AM
Duane_in_Japan's Avatar
Dont waste your time checking pressures, where did that come from, every AC man wants to know both pressures every time but sometimes only the LO pressure will suffice, we need pressures to help better, with only two wires on the receiver drier it is the HI pressure cutout switch, and yes you are grounding it, go to autozone and get the pressures checked with the system running, it sounds like you will have to use your test light to get the system to work.
JJT211
Apr 8, 2013 09:11 PM
95LSv
Honda Civic (2001 - 2005)
Jun 21, 2010 03:05 PM
AtoZ
Apr 15, 2010 06:28 AM
Kevinarich
Apr 3, 2006 03:11 PM
