Engine braking...
Old Apr 23, 2002 | 05:34 AM
Duck Sauce's Avatar
Default Engine braking...
During track events where you approach turns at high speed, and you might need to downshift from 3rd to 2nd for a brief moment, how bad is it for your engine to "engine brake" it? Is it just as hard on the tranny or mainly just the engine? TIA.
Old Apr 23, 2002 | 07:07 AM
hybridreams's Avatar
Default Re: Engine braking... (DC2ownz)
Try learning how to heel-toe. I don't track race but I'm trying to get the hang of it just 'cause. 1K!!
Old Apr 23, 2002 | 09:22 AM
ITC Racer's Avatar
When at the track, you generally are either on the brakes or on the gas. Based on this, if you are using only engine braking, you were not going fast enough...
When approaching a corner, brake in a straight line and step on the gas as you start your turn-in and power through the corner.
If this did not answer your question, please restate.
Old Apr 23, 2002 | 09:27 AM
Geezer's Avatar
Back when brakes weren't so hot, people did downshift to get engine braking and avoid fading the brakes for a little longer. This was mostly in competition, where you didn't much care if you wore out the clutch and gearbox, as long as you won. But weak brakes aren't much of a problem anymore.
Now the only reason to downshift is to be in the powerband when you accelerate through a turn. Hence you generally want to downshift as late in the braking as possible, just before you get off the brake and start your turn in.
http://www.turnfast.com has a nice tutorial on heel & toe braking, as well as other track skills.
Old Apr 23, 2002 | 09:38 AM
MaddMatt's Avatar
Default Re: Engine braking... (Geezer)
Yep, use the brakes to stop the car, not the engine. You won't slow down any faster using the engine anyway. Brake pads are cheap and easy to replace compared to a clutch.
Old May 6, 2002 | 09:45 PM
SIK IN DA HED's Avatar
New User
i didnt even know you could reach the pedal?
Old May 7, 2002 | 02:11 AM
.Ryan's Avatar
Don't Trust Anyone
Default Re: Engine braking... (dlplayboy)
I would just use my feet to Brake, like the Flinestone's.
Fuuma0083
47
Mar 8, 2010 02:28 PM
HondaHeddie
11
Feb 17, 2007 07:45 AM
DIRTYsouthBB6
Mar 19, 2006 02:01 PM
BlackAckeR
Oct 5, 2002 06:41 AM
