cant Find connector to reset ECU, need help
Old Jul 28, 2006 | 02:59 PM
Token Blk Guy's Avatar
So what I drive a Volvo
Default cant Find connector to reset ECU, need help
I have a 99 accord ex and i cannot find the connector, I looked al through the FAQ's and searched and where it says it is supposed to be it is not. Can anyone help out thanks!!
Old Jul 28, 2006 | 03:24 PM
thatasiankidtony's Avatar
Default Re: cant Find connector to reset ECU, need help (Token Blk Guy)
Try behind the ash tray
Old Jul 28, 2006 | 04:16 PM
Default Re: cant Find connector to reset ECU, need help (thatasiankidtony)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by thatasiankidtony &raquo;</TD></TR><TR><TD CLASS="quote">Try behind the ash tray</TD></TR></TABLE>
The ash tray on the left or is that the coin tray?
Old Jul 28, 2006 | 05:39 PM
someone else's Avatar
It Wasn't Me!
Service port is under the dash next to the drivers kick panel. I believe you have to know the pinout of which connector to jump.
Old Jul 28, 2006 | 07:03 PM
Default Re: cant Find connector to reset ECU, need help (someone else)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by someone else &raquo;</TD></TR><TR><TD CLASS="quote">Service port is under the dash next to the drivers kick panel. I believe you have to know the pinout of which connector to jump. </TD></TR></TABLE>
i was reading its 8 abd 13! So i can use the paperclip on the black service port there. I looked allaround for the brown and black wire connector no dice. Its not as easy as locating the one in my lude!
Old Jul 29, 2006 | 05:17 PM
JimBlake's Avatar
I bet it's the same as my '98 Accord...
That connector is for reading the error codes, not for resetting.
Key off. Open right-front door.
Open the fusebox in that of the dashboard -
Remove fuse #13 for a minute or so.
Put it back in & go.
If you're trying to reset a CEL, remember that if you haven't fixed the problem, the CEL will just come back.
Old Jul 30, 2006 | 09:53 AM
Default Re: cant Find connector to reset ECU, need help (JimBlake)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JimBlake &raquo;</TD></TR><TR><TD CLASS="quote">I bet it's the same as my '98 Accord...
Im trying to read the CEL, i looked at the service port and when i put a paperclip inside of it it went all the way through and didnt hit anything so i am confused at this point!
well i found the problem the pins are wrong. Its number 4 and 9 on my accord.
I got 17 flashes. VSS fault!! I dont think that is the problem the speedo works fine. I was thinking it had to do something with the O2 sensor. Since this car gets only 24 mpg on a good day and it should be getting over 30 for a accord EX if i am not mistaken! And i spent all this money tuning it up!
Modified by Token Blk Guy at 12:09 PM 7/30/2006
Funanin
Dec 28, 2007 10:19 AM
builthatch
Aug 22, 2006 07:22 PM
Mrfeee1
Jan 30, 2006 11:00 AM
LBBP R
Dec 15, 2005 11:48 AM
89hbcivicguy
22
Mar 13, 2005 07:11 AM
