Which grease for repacking vss?
Old Jul 28, 2006 | 02:50 PM
1accord's Avatar
Default Which grease for repacking vss?
Our 91 accord has fairly low miles. Because it seemed to be acting up, we took apart the vss but everything inside looked like new. At ://techauto.te.funpic.org/vss.php they say to repack the vss with contact
grease (then later they say to use conducting grease). We bought a very expensive tube of carbon conducting grease but are now thinking this might not be the right stuff to use. A glob of the black original grease was tested with an ohm meter and showed TOTAL RESISTANCE unless the probes were touched together in the grease. Durablend wheel bearing grease and Permatex dielectric grease showed a similar reading. The carbon conducting grease of course showed zero resistance across an inch of grease. Would appreciate knowing what type and brand of grease has worked for others?
Old Jul 28, 2006 | 02:54 PM
YeuEmMaiMai's Avatar
Default Re: Which grease for repacking vss? (1accord)
call the honda dealer and ask them. I would stick with the recommendation they give.
Old Jul 28, 2006 | 09:19 PM
1accord's Avatar
Default Re: Which grease for repacking vss? (YeuEmMaiMai)
Talked to the Honda Parts Dept and they don't have a clue as to what grease to use. They say they don't carry anything specifically for that. Don't think Honda wants you to fix or repack the vss units. They would rather sell you a new one for $157. It is super simple operation to remove 3 screws, take the cover off then clean and repack IF YOU KNEW THE RIGHT GREASE TO USE! There is only one moving part inside. Turns out there is nothing wrong with our vss and it looks perfect inside. We found out the drive link is not spinning even when the tires are turning, so we probably need a new vss gear shaft. If anyone has repacked a vss unit we would sure appreciate finding out which grease worked for you? We're considering dielectric but don't know if it will work or lubricate well enough.
Art Vandeleigh
May 24, 2016 08:56 PM
raverx3m
Jan 16, 2016 08:44 PM
JDMCRX
Jul 9, 2009 12:38 PM
fe519
Feb 27, 2005 09:31 PM
Mt3c
Aug 14, 2003 05:21 PM
