OT: Looking for a specific bolt. Any hardware guys out there?
This is the tech drawing for the bolt I'm looking for. The bolt can be longer, but the other dimensions must remain the same. Thanks guys.
http://img524.imageshack.us/im...s.gif
I forgot more about hondas then you will ever know....
From: hop,skip, and a jump from the city,, new friggin york, USA
i told "him" to just use another bolt with a different pitch and just retap the hat. it would have been up and running a LONG time ago...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by zygspeed »</TD></TR><TR><TD CLASS="quote">LOL! That looks familiar!
Sorry, ... is Rob still looking for that?</TD></TR></TABLE>
Oh jesus... that bolt.
what's it do? if it is the rotor retaining bolt... you do know it's really unnecessary, although, before i figured that out, the "help!" tools section at autozone carries it
I can't find an M10 x 1.25 X 35, except for at buddyclub (and they have failed to ship the bolt time and time again). I have found a countersunk M10 X 1.25 X 40 w/ 6mm hex socket though.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 97 TYPE-R 312 »</TD></TR><TR><TD CLASS="quote">So now both of you guys need this bolt?
-Victor</TD></TR></TABLE>
no.... Ed needed the bolt, now "he" needs the bolt after purchasing the suspension from Ed
metric system FTW
are you only supplied with bolts with inch spec in usa, or is that just uncommon?
:update: could you get a hold of a bolt with a regular hex head, put a washer under and get a machine shop to make a "countersinc washer"
A bit far away from you but usually this kind of stuff is standard issue in Canada. I can call on the industrial supply store on Monday. What material/finish specs; stainless, black oxide, zinc? How many do you need?
It took me a while to find. It's actually for a marine application. All the dimensions are the same except for the length, but aparently that is not an issue.
And to George at buddy club: Grrrrrrr......
</TD></TR></TABLE>It took me a while to find. It's actually for a marine application. All the dimensions are the same except for the length, but aparently that is not an issue.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mythias »</TD></TR><TR><TD CLASS="quote">"he" said that the M10 x 1.25 x 40mm counter sunk 6mm hex socket bolt I found will work.</TD></TR></TABLE>
So case closed? Or
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by stumpyf4 »</TD></TR><TR><TD CLASS="quote">A bit far away from you but usually this kind of stuff is standard issue in Canada. I can call on the industrial supply store on Monday. What material/finish specs; stainless, black oxide, zinc? How many do you need?</TD></TR></TABLE>
Let's see what you can come up with.
So case closed? Or
You ITr guys worry me sometime.... "think outside the hype"
http://www.metricmcc.com/
Oh and I'm not sure if they have that bolt but they have lots of good fasteners
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ekasey »</TD></TR><TR><TD CLASS="quote">You ITr guys worry me sometime.... "think outside the hype"
http://www.metricmcc.com/</TD></TR></TABLE>
We worry you because a single bolt seems so elusive? If so, then find it. Think outside the hype, eh? Us ITR guys would never think to check a site that specializes in metric size fasteners or out of country.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ekasey »</TD></TR><TR><TD CLASS="quote">Oh and I'm not sure if they have that bolt but they have lots of good fasteners</TD></TR></TABLE>
So you tell us to "think outside the hype," and suggest a site not knowing if they do or do not have the particular bolt (which, in fact, they do not)? You were given the schematics of the bolt. It would have taken you no more than 1 minute of your time to check to see if they have it or not. To make such suggestions that we can not think outside the hype, and to post a website that you have no idea if they do or do not supply the part in question, is absurd.
This particular bolt is for a buddyclub suspension system, and even buddyclub is not able to provide the bolt. I have found a bolt that meets the necessary criteria, and is for a marine application. How is that not thinking "outside the hype?"
This is a metric flat head cap screw but in fine thread. Unfortunately it's not in stock at the local Brafasco (fastener store). It can be ordered in but the whole box must be taken since they don't want to stock this size. It would be black oxide finish.
bro, that place is like 40 min from me. i recommended it right off the bat. they have the exact bolt, but in a slightly diff pitch. i would have been all over that. wtf cares if you have one nut different then the rest. **** still works the same.....
This particular bolt is for a buddyclub suspension system, and even buddyclub is not able to provide the bolt. I have found a bolt that meets the necessary criteria, and is for a marine application. How is that not thinking "outside the hype?" </TD></TR></TABLE>
Seriously. I'm scratching my head at "Ekasey"s comment.
hey bud i went today and they have the exact bolt except length is at 25mm instead of 30mm
but they can custom cut you a bolt in the exact measurements you want. i gave them the bolt diagram so they are just waiting for you to call to see if you want them to make it for you...
talk to Henry Ayon at 1-800-800-6696 place is called Metric Specialties in Burbank. http://www.metricspecialties.com/
like i said they had like 4-5 bolts already there everything the same except a 25mm bolt length.
not sure if you have a place nearer you that does custom cut bolts or not but there you go...
also the quality is superb. the bolts they had there were a custom job aswell and they turned out nice and clean and smooth.
Drinker
