h22?
Old Jul 28, 2006 | 02:15 PM
Felt.2's Avatar
Default h22?
i just finished putting my h22 delsol back together. and i cant get it into gear but only when the car is running when its of it shifts just fine im going crazy. its a chipped p28 h22 swap worked fine before i took it apart ha any ideas please help
Old Jul 28, 2006 | 03:04 PM
sohcvtec1995's Avatar
Default Re: h22? (Felt.2)
so it only goes in gear when its off? make sure to check all the clutch connections, fluid. but sounds like you forgot to put something in. or something is in wrong
Old Jul 28, 2006 | 03:06 PM
Syndacate's Avatar
Default Re: h22? (sohcvtec1995)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sohcvtec1995 &raquo;</TD></TR><TR><TD CLASS="quote">so it only goes in gear when its off? make sure to check all the clutch connections, fluid. but sounds like you forgot to put something in. or something is in wrong</TD></TR></TABLE>
agreed, sounds like a clutch problem, as you don't need the clutch to shift when it's off...
EDIT:
Check the clutch cylinder, make sure the system has fluid, and if need be rebuild the clutch setup, maybe you put something in wrong (dunno how u could have) but **** happens...
ALso check the clutch linkage
orc1014
Mar 3, 2015 09:26 PM
charliebcdaccord
Jul 16, 2009 08:15 PM
boosted92hatch
Feb 20, 2008 09:26 AM
yourfacesucks
Aug 23, 2003 04:04 AM
Toretto
Aug 1, 2003 02:48 PM
