Clutch Arm movement/ trouble shooting
I own a 1988 Crx Si w/ JDM B16a swap. I have been having problems shifting and getting it into gear since the swap. The tranny seems to be fine, but it is a clutch problem or mabye it is the pressure plate or TOB.
I'm trying to trouble shoot the problem before I rip everything apart. So I'm hoping that you guys might be able to help!
Ok here is a picture of the clutch pivot arm ( W/ the clutch cable taken off ) in the resting position. Now from the resting position to where it gets hard to pull up is where I have illistrated in red. There is SOOO much play untill it puts pressure on the TOB. I would say 2/3's of the total travel is just loose. Then with the clutch cable maxed it will just hardly go into gear.
Now here is a picture it pulled all the way up.
Here is a over all picture of my engine bay b/c it's sexy
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by onepoint6i »</TD></TR><TR><TD CLASS="quote">thats with the adjustment of the cable threaded all the way, right?</TD></TR></TABLE>
When it is all the way tight then I can put the car into gear but it is very hard.
MORE HELP BOYS!!!
MORE HELP BOYS!!!
Guest
Posts: n/a
It's suppose to be like that when you do the swap, because they say "some companys" that when you do the swap you have to use a 90/91 integra clutch cable itself for the proper adjustment. They also say you can use your stock clutch cable but it will be tight and very annoying in stop and go traffic, plus it's more prone too breaking sooner anyways.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Contender25 »</TD></TR><TR><TD CLASS="quote">It's suppose to be like that when you do the swap, because they say "some companys" that when you do the swap you have to use a 90/91 integra clutch cable itself for the proper adjustment. They also say you can use your stock clutch cable but it will be tight and very annoying in stop and go traffic, plus it's more prone too breaking sooner anyways.
I used a 90 Integra clutch cable. I also just replaced it with a new one. It was not the problem.
I wan to know if that much travel is normal, or what might be causing that much travel?
</TD></TR></TABLE>I used a 90 Integra clutch cable. I also just replaced it with a new one. It was not the problem.
the travel seems normal to me too. the looseness in the arm you will have. but you should have about 2" that the arm moves that it is actually doing something. ( hard resistance after the play in the lever ) but you shouldnt feel the play in the lever on your foot when the cable is attached. if you do you've got something wrong and pull it apart.
im having the same problem but i cant put it in gear at all. i havent tried to adjust the cable all the way. Ill try it, But i dont want to take the tranny off untill i find out more about what my problem is.
it will only try to go into reverse and it will start to grind. is this a clutch problem.
thanks
thanks
stock SiR linkage and 91 integra clutch cable
it goes into gear when the car is off and it goes in smoothly but when i start the car it doesnt want to go into gear
I had the same promblem with my b16a swap, this is my experience i had measured, and cut my old links to fit, and when i got them welded they were twisted 5 degrees off and it was a bitch to put in gear, very hard when the adjuster was tighten all the way, if you did weld your own links you might want to check it out, lay them flat on the ground and make sure it lays flat. And if you didnt....i dont know. once i had it working again a year later my TOB little metal rod that pushes it out one side broke, so it was putting half pressure on the pressure plate. Thats the only advice i can give off my own personal experiences with getting the car in gear.
When my car was off it shifted fine then the sceond i turned it on it got really hard, I even broke a shifter **** so if you cant find anything else take off the links and see if they lay flat. you have to take off the links to drop the trans anyway so take a look at it.
My D16a6 is just like that. I have a lot of play and I was wondering the same thing.
Try loosening the cable so the cable has about an 1/2" of slack when you pull on it and the arm is resting in the upmost position where the arm is resting on the t/o and pressure plate.
This will move the clutch engagement toward the floor. This is the proper adjustment.
However I can get into all my gears smoothly. I am sorry I have to tell you what you don't want to hear...You have to inspect it. Could be internal too.
I had the same problem you have to tighten it a real lot even after the free play is gone. I ended up adjusting it then using a pry par to pry the lever up to get it to go on and be super tight.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LankorDie »</TD></TR><TR><TD CLASS="quote">My old thread is back
Thanks CrxJimmy, but the problem is cured now
I brought it back.
what did you do to fix it? i have the same problem
</TD></TR></TABLE>I brought it back.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Zaakro »</TD></TR><TR><TD CLASS="quote">
I brought it back.
what did you do to fix it? i have the same problem</TD></TR></TABLE>
Oh! No problem, you guys must have just missed my big thread
https://honda-tech.com/zerothread?id=1770756
If that does not help, pm me I got tons of info from so much trouble shooting
I brought it back.
LankorDie
61
Aug 17, 2006 07:40 AM
Luserkid
16
Nov 13, 2004 08:57 PM
