sohc timing belt question
Old Jul 28, 2006 | 11:34 AM
TallKyle's Avatar
Default sohc timing belt question
I am building a turbo D and i am using a Z6 block with an A6 head. Ask why well cuz i had a cam and what not laying around for the A6. I just ordered an A6 timing belt and it was too loose on my motor. I am kinda stumped cuz i thought the Z6 belt was larger then the A6 one. Any input on this?? Thanks
TK
Old Jul 28, 2006 | 12:39 PM
Ls1 FD3s's Avatar
Default Re: sohc timing belt question (TallKyle)
I am not much of a D-series guru, in fact i HATE EM, STANK! BUT...
Measure the diamter of your crank cog for the timing belt on both engnines, measure the tensioner, measure WATER PUMP (i know i read that one style has 1 tooth more or one less, i forgot) Check the cam gear diameter just incase, but i know the cam gears are all the same. IF they all measure out correctly, take measurements of the block's deck heights, and measure the head's distance from center of cam gear to the deck... Unless someone is ******* with you and gave you the wrong timing belt. Try all what i said, its what i'd do... Except i would toss the SOHC in the lake and buy a B18c Dual cammer slammer....
Old Jul 28, 2006 | 07:57 PM
TallKyle's Avatar
Default Re: sohc timing belt question (Ls1 FD3s)
yea i went to auto zone and bought a 94 Dx belt and it works. i returned it already and ordered an oem one. +1 for me. thanks jimmy for helping though.
scoob8000
Dec 19, 2011 11:57 AM
garageEF
Apr 30, 2007 04:47 PM
burgerbuddy
15
Sep 9, 2005 12:58 PM
UndergroundVR-4
Jan 13, 2005 09:52 AM
