What are yoru egt's like on the highway?
Old Jul 28, 2006 | 11:15 AM
Boostage's Avatar
Default What are yoru egt's like on the highway?
Just keeping up with the flow of traffic, anywhere from 70-80mph egt' s are just over 1300 degrees farenheit sometimes 1400. my probe is about 3 inches from the exhuast housing on the DP so I can only assume that the temps are even hotter than 1400. what are you all seeing?
Old Jul 28, 2006 | 12:05 PM
lodo's Avatar
Default Re: What are yoru egt's like on the highway? (Boostage)
i'm seeing 750-800 degrees celsius 2 inches from the head on my b16
Old Jul 28, 2006 | 12:12 PM
teamlegacy's Avatar
Default Re: What are yoru egt's like on the highway? (lodo)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lodo &raquo;</TD></TR><TR><TD CLASS="quote">i'm seeing 750-800 degrees celsius 2 inches from the head on my b16</TD></TR></TABLE>
Which is between 1350 and 1475 degrees fahrenheit. I'd say your temperatures are good to go.
Old Jul 28, 2006 | 12:15 PM
ghostskinner's Avatar
thats about the same as <TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Boostage &raquo;</TD></TR><TR><TD CLASS="quote">Just keeping up with the flow of traffic, anywhere from 70-80mph egt' s are just over 1300 degrees farenheit sometimes 1400. my probe is about 3 inches from the exhuast housing on the DP so I can only assume that the temps are even hotter than 1400. what are you all seeing?</TD></TR></TABLE>
Old Jul 28, 2006 | 12:19 PM
Suprdave's Avatar
Why does it matter? That's very low load...you aren't going to melt anything...
Old Jul 28, 2006 | 12:27 PM
Boostage's Avatar
Default Re: What are yoru egt's like on the highway? (Suprdave)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Suprdave &raquo;</TD></TR><TR><TD CLASS="quote">Why does it matter? That's very low load...you aren't going to melt anything...</TD></TR></TABLE>
What is the melting point?
Old Jul 28, 2006 | 01:03 PM
Muckman's Avatar
Moderator in Chief
~1600*F
Old Jul 28, 2006 | 01:28 PM
turbotime's Avatar
shouldnt there be concern if one person is seeing ~1400F 2" from the exhuast port and another is seeing ~1400 3" form the turbo outlet?
I would think that 3" down the downpipe temps would be a bit lower than 1400F
Old Jul 28, 2006 | 03:48 PM
96 GSR-T's Avatar
Default Re: (turbotime)
^^^ What he said, if your 1400 @ the DP then I would imagine atleast 100 deg hotter @ the head
Old Jul 28, 2006 | 03:55 PM
Finland's Avatar
mine are about 1400-1500 cruising at 80mph. the probe is about 2" from the exhaust port.
Old Jul 28, 2006 | 05:17 PM
jspeedy's Avatar
I'm also seeing 750c right at the manifold. I don't think 1600 is the melting point concidering I usually reach 900c or more that the track. although that's just for a few seconds then back down to whatever is normal for idle, 500c, or whatever speed I'm traveling.
Old Jul 28, 2006 | 05:26 PM
non-VTEC's Avatar
What is the melting point?</TD></TR></TABLE>
aluminum melts at 1350
Old Jul 28, 2006 | 05:30 PM
nfn15037's Avatar
Default Re: What are yoru egt's like on the highway? (non-VTEC)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by non-VTEC &raquo;</TD></TR><TR><TD CLASS="quote">aluminum melts at 1350 </TD></TR></TABLE>
And what inside of an engine is pure aluminum?
Old Jul 28, 2006 | 05:32 PM
non-VTEC's Avatar
Default Re: What are yoru egt's like on the highway? (nfn15037)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nfn15037 &raquo;</TD></TR><TR><TD CLASS="quote">
And what inside of an engine is pure aluminum?</TD></TR></TABLE>
the cylinder head and pistons
Old Jul 28, 2006 | 07:12 PM
turbocrex's Avatar
some of you are talking about Celcius and some farenheight, so don't get confused
Old Jul 28, 2006 | 08:18 PM
Dunc's Avatar
BCICAN
That doesn't mean that your head is that hot just because the gases in the exhaust are that hot.
Old Jul 28, 2006 | 08:45 PM
nfn15037's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by non-VTEC &raquo;</TD></TR><TR><TD CLASS="quote">the cylinder head and pistons </TD></TR></TABLE>
Ever heard of an alloy?
Dead CIVIC
Mar 5, 2008 11:26 AM
Hondizzle!
Jan 3, 2007 12:26 PM
redpeppers
Sep 13, 2005 10:18 PM
compwc18
May 20, 2004 01:19 AM
89civichatchback
31
Sep 26, 2003 07:55 AM
