My R was shaking VIOLENTLY, what could it be??
Old Apr 23, 2002 | 04:22 AM
hooptie157's Avatar
Default My R was shaking VIOLENTLY, what could it be??
I was riding down the highyway looking for a restaurant my friend works at and then the exit came out on no where. So I downshift REALLY fast while braking and made the exit. I was going about 80 and I broke to about 30 while taking the turn. When I was looking for a spot I noticed It felt like teeth hitting the shifting as I put it into third. I parked in a space put in in neutral and put the brake on. I car than began to shake violently. I stepped on the clutch and it shook more. I turned the car off and called acura roadside. They towed the car on friday stored it at a tow yard until monday and then brought it to the dealership. Yesterday the dealership calls me and says nothings wrong. They said they had someone drive the car around for 20 min and nothing was wrong. So I took my baby back and went home and its not doing the shaking right now. What could have caused this??
My current mods:
ATS final drive
Exedy organic Clutch
Toda 9lb flywheel
Mugen Header
Mugen twin loop exhaust
carsound cat
comptech icebox w/filter
can you guys help?
Old Apr 23, 2002 | 04:29 AM
MiraiZ's Avatar
Default Re: My R was shaking VIOLENTLY, what could it be?? (hooptie157)
Does it happen when you brake? If so, it sounds like warped rotors due to excessive heat....
[Modified by MiraiZ, 10:30 PM 4/23/2002]
Old Apr 23, 2002 | 04:43 AM
hooptie157's Avatar
Default Re: My R was shaking VIOLENTLY, what could it be?? (MiraiZ)
it was shaking while idling, how could that be he brake when the car was not moving
Old Apr 23, 2002 | 05:13 AM
01TypeR680's Avatar
New User
warped his parking break j/k
Old Apr 23, 2002 | 05:22 AM
Dr Pooface's Avatar
Default Re: My R was shaking VIOLENTLY, what could it be?? (01TypeR680)
How are your motor mounts?
Old Apr 23, 2002 | 05:37 AM
hooptie157's Avatar
Default Re: My R was shaking VIOLENTLY, what could it be?? (Ddub)
thats a great question, BUT I checked them when it happened and they seemed fine. It was at night though so I couldn't really see the rear two mounts.
Old Apr 23, 2002 | 06:30 AM
newt2's Avatar
INSERT TITLE HERE
25 Year Member
Community Builder
Loose spark plug wire would be the first thing I'd check. It'll shake pretty bad if it's firing on three cylinders.
Old Apr 23, 2002 | 06:32 AM
hooptie157's Avatar
Default Re: My R was shaking VIOLENTLY, what could it be?? (newt2)
spark plugs huh I'll check that right now
Old Apr 23, 2002 | 06:40 AM
adam's Avatar
in that case the CEL should be on
Old Apr 23, 2002 | 06:47 AM
newt2's Avatar
INSERT TITLE HERE
25 Year Member
Community Builder
Default Re: My R was shaking VIOLENTLY, what could it be?? (adam)
Even if it just misses for a little bit? How would the ECU even know?
Old Apr 23, 2002 | 07:19 AM
PiYoImuT's Avatar
Try idling it for 10 minutes in that SHAKE Mode..
if the CEL comes on, check it out.
Happened to Me Before. BAD GAS.
I Avoided that Gas Station and that thing never happen again.
Old Apr 23, 2002 | 07:20 AM
hooptie157's Avatar
Default Re: My R was shaking VIOLENTLY, what could it be?? (PiYoImuT)
it stopped shaking and I can't make it do it again and I'm on the same gas tank
Old Apr 23, 2002 | 11:21 AM
kkim's Avatar
fouled spark plug, maybe? running it could have burnt off what ever was fouling it. pull the plugs and inspect the color of the electrodes.
Old Apr 23, 2002 | 11:33 AM
jonas's Avatar
Default Re: My R was shaking VIOLENTLY, what could it be?? (kkim)
earthquake
Old Apr 23, 2002 | 11:53 AM
SoCal ITR's Avatar
Default Re: My R was shaking VIOLENTLY, what could it be?? (jonas)
earthquake
hahaha, a bad spark plug sounds plausible, but then again, I don't know all that much about it.
Old Apr 23, 2002 | 12:09 PM
itr--779's Avatar
New User
Default Re: My R was shaking VIOLENTLY, what could it be?? (SoCal ITR)
Weird.
Don't worry about it unless it happens again.
I guess...
Old Apr 26, 2002 | 10:25 AM
hooptie157's Avatar
Default Re: My R was shaking VIOLENTLY, what could it be?? (itr--779)
it happened again, but this time I made it happen and I have an Idea what it is.
This is what I did. In neutral I reved the car to about 4k and let off the gas. As the RPM's dropped FAST (due to lightened flywheel) they fell close to 1 rpm, this made the car shake like crazy until I gave to alittle gas, then it subsided. I reved the car again to about 4k but this time I held it there to see and hear what would happen. As I was holding it there it sounded like the engine was not very smooth, it kinda sounded like it was pulsating slightly and went I let off the gas quickly the shaking happened again but only slightly, not as violently as last time. Could this be a warped or impoperly installed flywheel (it is toda)?? Any help would be greatly appreciated
[Modified by hooptie157, 7:28 PM 4/26/2002]
Old Apr 26, 2002 | 10:28 AM
yoshi234's Avatar
I shoot brides
ah, the light flywheel! so when the RPMs dropped it probably fell below the normal idle speed causing the engine to sputter and shake.
yshi - who wonders how light that flywheel is
Old Apr 26, 2002 | 11:18 AM
hooptie157's Avatar
anyone?? (other than yoshi, oh yeah yos its the 9lbs toda flywheel and the ATS final)
tukai
Honda Civic (2006 - 2015)
48
Oct 9, 2007 05:32 PM
TehMoonRulz
13
Feb 18, 2005 01:10 PM
hooptie157
Apr 16, 2003 06:35 PM
azn98R
Mar 3, 2003 10:01 AM
hooptie157
May 31, 2002 04:08 PM
